Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    ROG Member Array
    Sep 2014
    Crosshair VIII Hero WiFi with Ryzen 9 3950X won't start.
    I am trying to get the system below to start. Can't even get it to load the microcode into the CPU so no BIOS settings etc. Just fails with code 02. I flashbacked the bios to the latest version from the Web site (2206).
    Thing is, I spent half a day putting the machine together, its a water cooled build. And given comments here, wondering what sending the board back will achieve beyond someone "testing" it with the wrong CPU, declaring it works and sending me back a board that won't boot because the software is foobar.
    Has anyone got this motherboard to run with a 3950X? If I send it back will they actually check it with the correct chip? How can I determine if it is the chip or the motherboard that is faulty here?
    This is my first experience with an AMD build after years of Intel. Wondering if I should cut my losses and go back.
    ASUS AMD AM4 ROG X570 Crosshair VIII Hero (Wi-Fi) ATX Motherboard with PCIe 4.0, Dual M.2, SATA 6Gb/s, USB3.2 Gen 2, 2.5Gbps LAN, WiFi 6
    AMD Ryzen 9 3950X 16-Core, 32-Thread Unlocked Desktop Processor
    CORSAIR AX Series AX1000 CP-9020152-NA 1000W ATX12V 80 PLUS TITANIUM Certified Full Modular Power Supply
    G.SKILL Trident Z Neo Series 128GB (4 x 32GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C16Q-128GTZN
    ROG Guru: White Belt Array
    Dec 2018
    15
    118
    Dear ,
    You've mentioned almost everything expect .. > GPU ?
    Mainstream Ryzen doesn't have onboard graphics. A dedicated GPU is required for use.
    Please note that i dont use AMD but i will try to help you if that possible .
    Also , Check you may 've loose cable
    check <PSU cable>
    Thanks .
    ROG Member Array Ziggiesden PC Specs
    Ziggiesden PC Specs
    Laptop (Model)Alienware Area51-m i9 10900K 64GB 4TB (RAID 0)
    MotherboardASUS ROG Crosshair VIII Hero & Formula
    Processor2*AMD Ryzen 9 3950X Processor @4.315Ghz
    Memory (part number)Corsair Vengeance LPX 64@4000Mhz
    Graphics Card #1Asus TUF 3090 OC 24GB
    Graphics Card #2EVGA GeForce RTX 2080 Super XC Ultra (Overclocked)
    Graphics Card #3NITRO+ RADEON RX 5700 XT SP ED
    Graphics Card #4Sapphire Nitro+ Radeon RX 5700 XT 8G, 8192 MB
    Monitor2* 55 Inch Samsung Curved TV's 4K
    Storage #12*Sabrent 1TB Rocket Nvme PCIe 4.0 M.2 2280
    Storage #27*Samsung 860 QVO 1 TB SATA 2.5 Inch Internal Solid State Drive (SSD)
    CPU CoolerNZXT Kraken X62 280mm
    CaseFractal Design Meshify C
    Power SupplyCorsair AX1600i / BeQuiet 1000 W Dark Pro 11
    Keyboard Logitech K540
    Mouse Logitech M310
    Headset Sades
    Mouse Pad Gargoyles
    Headset/Speakers 2*Q60T
    OS Windows 10 Enterprise
    Network RouterZyxel
    Accessory #1 LSI MegaRAID SAS 9271-8i 1GB DDRIII 8 Port 6Gbps PCIe 3.0 SATA SAS RAID Controller Kit
    Aug 2020
    12
    ASUS P5Q3 Deluxe Woes
    Back in 2009 I had a bad board and it took a wee bit of swapping components with friends to realise it was the board that was faulty.
    Sent it back, got my replacement and it is still running right now with a QX9750.
    Play the swap game if you can, if not return a component at a time, after you've tried a stick or two at a time to see if it boots...
    Break a leg!
    You'll see from my specs that I've been running just that for a month or so now.
    Gary.
    ROG Guru: Brown Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 11 64bit Pro
    Network RouterPfSence Intel i5-10210U 6 Port
    Accessory #1 TP-Link Gigabit 8&6 Port Switches
    Apr 2018
    65
    1,238
    The board can run CPU without issue.
    Both EATX connectors (top left from CPU) must be connected for 3900x & 3950x CPU's or no boot.
    Did you change the CPU backplate by chance. Overtightening of the CPU waterblock can cause non-boot and if you reverse the CPU backing plate (some come with their own and can be mounted backwards) can result in non-boot or Q code.
    You should place one ram stick in A2 till you have boot. Once you have boot, you can add your sticks back in.
    The RAM you have is not AMD QVL list when I searched for it (no big deal)
    https://www.amd.com/en/products/ryze...-gen-amd-ryzen
    but is on G.skill for the motherboard & Ryzen 3000 series. (this is good)
    https://www.gskill.com/qvl/165/326/1...6Q-128GTZN-Qvl
    Hope you find this helpful.
    ROG Member Array BIGGRIMTIM's Avatar
    Jan 2011
    18
    I had the exact same issue with the 2206 BIOS. I am using 1302 and have been stable. I have tried every other BIOS release and nothing beyond 1302 is good for my 3950x.
    ROG Enthusiast Array wyliec2 PC Specs
    wyliec2 PC Specs
    MotherboardROG Crosshair VIII Formula
    ProcessorAMD 3950x
    Memory (part number)G.Skill Trident Z Neo DDR4-3600 (2x16Gb)
    Graphics Card #1Gigabyte GTX 1050 Ti
    MonitorViewSonic VP2768-4K PRO 27" 4K
    Storage #1Corsair MP600 1Tb Gen4 NVMe
    Storage #2Samsung SSD 500 GB x 2
    CPU CoolerNZXT Kraken X62 280mm AIO
    CaseCorsair Obsidian 450D
    Power SupplySeasonic Focus 850 Gold
    Network RouterASUS RT-AC88U (Merlin firmware)
    Jun 2020
    29
    I second the suggestion to try starting with individual RAM modules or maybe even better if you have an 8 or 16 GB module just to get to a minimally functional baseline....
    I have Crosshair VIII Formula with 3950x - it's interesting the experiences with different BIOS versions people are reporting.....for me, 1302 and 2010 were buggy - crashing/freezing on a regular basis. 2103 was the first version that gave me a truly stable platform. I recently updated to 2206 and it's been good so far.
    I'm using 2x16GB g.skill Trident 3600 CAS 16 RAM with Corsair MP600 1 TB nvme PCIE-4 SSD and Gigabyte 2070 Super.
  7. #7
    ROG Member Array
    Sep 2014
    Thanks for the help!
    Quote Originally Posted by lLegendaary View Post
    Dear ,
    check <PSU cable>
    Thanks .
    The GPU is (currently) an nVidia GTX 980 pulled from the machine the new build will replace. Now is not the time to buy an upper end nVidia GPU...
    Machine is currently stripped to one stick of DRAM and the GPU is out while trying to get POST as per ASUS tech support. Will try fiddling with the cpu back plate as suggested.
    Will probably strip it right down and rebuild, see if that does the trick.
    How do I get a copy of the earlier BIOS to see if those work?
  8. #8
    Jan 2011
    18
  9. #9
    ROG Member Array Marvin K Mooney PC Specs
    MotherboardASUS ROG Crosshair VIII HERO
    ProcessorAMD Ryzen 9 3950x
    Memory (part number)G.skill 32gb 3600 cl16
    Graphics Card #1ASUS ROG STRIX GeForce GTX 1080 TI
    Sound CardXonar Essence STX
    MonitorASUS PG27UQ 4K
    Storage #1Samsung 960 EVO NVME m.2 1tb
    CPU CoolerCustom Water cooling
    CasePhanteks 719
    Power SupplyEVGA SuperNOVA 1600 T2, 80+ TITANIUM
    Keyboard ROG Strix Flare
    Mouse ROG Gladius II Origin
    Headset/Speakers Edifier S350DB
    OS Windows 10 Pro
    Marvin K Mooney's Avatar
    Aug 2013
    7
    I have the same issues I’ve had it for about 1-2 months with some slight issues then today I’ve been having nothing but bad post codes (02) I have tried every thing re-seating the GPU CPU RAM new CMOs battery flashing new bios nothing has worked.
  10. #10
    Ziggiesden PC Specs
    Mouse Logitech M310
    Headset Sades
    Mouse Pad Gargoyles
    Network RouterZyxel
    Aug 2020
    12
    1302 bios
    Quote Originally Posted by Marvin K Mooney View Post
    I too have random boot issues where I have to reload the settings before I can continue with my overclock.
    The system seems to perform some sort of internal bios check - seemingly it is some new stability test built into the newest firmwares. Mostly it is happy but sometimes I get an error code that some say is related to Infinty Fabric.
    Overall, I'm happy with my build but it could be better - BIOS improvement perhaps? As to 2206 I had weird things like USB ports not working so went back to 1302 which others too have found to be the most stable. Joy.
    Waiting in anticipation for another update - if we get one...
    Be careful out there!
