Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    New ROGer Array
    Jun 2020
    25
    crosshair VIII hero wifi : how many USB 3.2 Gen 1 connectors ?
    Hi, my Lian Li 011D Dynamic XL case has 2x2 USB 3 ports on the front panel. Each pair has the standard 20 pin USB connector. Now, on the motherboard I only found one USB 3.2 Gen 1 connector, which means I won't be able to use all of the 4 front panel USB ports. Is there maybe a second 20 pin USB connector I oversaw or is there a way to use the other set of USB ports with an adapter or anything ?
    ROG Guru: Blue Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    43
    878
    Apr 2018
    43
    878
    nvm, double posted for some reason.
    New ROGer Array
    Jun 2020
    25
    Quote Originally Posted by RedSector73 View Post
    yea that will definitely help, although it reduces speeds to a USB2 one... Thanks for the hint ! I'd still like to get some confirmation there's really just 1 USB 3 gen 1 port on the mobo from someone if possible.
    Apr 2018
    43
    878
    https://www.asus.com/au/Motherboards...pecifications/
    Let me know when you find one with more than one.... I've never seen it.
    New ROGer Array
    Jun 2020
    25
    ok will do. Just wanted to be sure...
  7. #7
    Apr 2018
    43
    878
    Quote Originally Posted by irepublicofgamers View Post
    Do you have the case yet because just checked and reading;
    Page 9 of manual.
    1x 3.1 Gen 2 20 pin header (x570 ch8 has one)
    1x 3.0 Gen 1 20 pin header (x570 ch8 has one)
    Which the motherboard and lots of others have.
    USB 3.2 GEN 1
    Should have picked up on this earlier, my bad. It has both of the ports just not 3.2 and match the case requirements (when I read the manual).
    The naming conventions for USB is an absolute dumpster fire.
  8. #8
    New ROGer Array
    Jun 2020
    25
    where do you see this ?
    On page 9 of the manual I'm reading 1.1.6 Onboard buttons (!)
    I simple don't locate a second 20 pin USB port on the motherboard. There's a USB3 gen 2 one (c-type) but that's it ...
  9. #9
    Apr 2018
    43
    878
    Here
    Website (then scroll to botom to find manual downloads).
    https://www.lian-li.com/pc-o11d-rog/
    Direct Download
    https://drive.google.com/file/d/1myD...usp=drive_open
    goto page mentioned.
  10. #10
    New ROGer Array
    Jun 2020
    25
    I already had that pdf.
    Of course, Liam Li offers a total of 4 USB3 ports grouped in two pairs with each a 20pin connector.
    That's not the issue.
    The problem is that I only find one 20pin connector on my motherboard, which made me wonder why Lian Li is even offering 2 sets if most of the motherboards don't ship with two 20pin slots anyway?
