Results 1 to 10 of 11
09-10-2020 01:43 PM #1
restsugavan PC Specs Motherboard RAMPAGE VI EXTREME BIOS 3701 MOD Processor Intel Core i9 7980XE 2.60GHz Memory (part number) 64GB GSKILL 3.2 GHz 16-16-18-36 2T Graphics Card #1 ASUS ROG POSEIDON 1080Ti Monitor SAMSUNG ODESSEY G9 NEO 49 Firmware 1005.1 Storage #1 SAMSUNG 970 EVO PLUS 1TB x 3 Storage #2 WD 4TB External HDD CPU Cooler NZXT KRAKEN 62 Case Corsair Carbine 540 Power Supply Corsair AX1200i Keyboard Microsoft Mouse Microsoft Mouse Pad ASUS Headset/Speakers Sony OS Windows 11 Insider Preview 25179.1000 Network Router D-LINK
- Join Date
- Sep 2017
- Reputation
- 138
- Posts
- 790
OMG WHO DESIGN ROG RAMPAGE VI EXTREME CMOS Battery placement!?
Why did ASUS Engineer design CMOS battery placement so badly?
Do you think ROG RAMPAGE VI EXTREME CMOS battery never run out ?
Only one battery replacement need more than 60 min to disassemble the ROG Armor.
Please do not use these method for next ROG RAMPAGE VII EXTREME for Icelake X
or not I will choose other brand instead.
Can’t believe the most expensive mobo also expensive time to replace CMOS battery 🔋
Beware everyone only 3 years battery run out shortly. And you’ll see this experience like me.
Windows 11 22H2 Build 25179.1000 Core i9 7980XE 02006D05 MCU 2021-11-13 R6E 3701 MODDED BIOS TPM 2.0 Enabled VROC 7.7.0.1054 + RST 18.31.3.5434 ME FW 11.12.92.2222 DV 2211.2.3.0 64GB DDR4 3200 XMP POSEIDON 1080i GTX NVIDIA Driver 525.26 WHQL 3TB SAMSUNG 970 EVO PLUS OMS Driver 18.37.1.1003 WHQL i219 V OROM 0.1.02 BA 0.1.16 12.19.2.45 WHQL AQC 107N FW 3.1.121 AQC 3.1.7.0 WHQL Realtek HD 6.0.9381.1 WHQL SAMSUNG ODYSSEY G9 49 NEO FW 1008 VESA HDR 2000 DP
09-10-2020 03:31 PM #2
- Join Date
- Jun 2013
- Reputation
- 37
- Posts
- 264
It has been returned to the conventional location on the R6EE so logically they will not do this stupidity again for the R7E
09-18-2020 06:23 AM #3
Abaidor PC Specs Motherboard Rampage VI Extreme Processor i9-7940X Memory (part number) F4-3600C17Q-64GTZR | Trident Z RGB 64GB Graphics Card #1 Asus Strix 1080Ti OC Storage #1 Samsung 960 Pro 512GB Storage #2 WD 10TB Gold CPU Cooler EK Rampage VI Monoblock Case C0smos 2 Modded Power Supply Corsair AX1500i
- Join Date
- Dec 2017
- Reputation
- 12
- Posts
- 261
OMG! - That means I need to disassemble my custom loop as well.......
Damn this is going to be a PITA and lots of "cursing"...........Asus Rampage VI Extreme | i9-7940X | 64GB Trident Z RGB 3600 | Asus Strix 1080Ti OC | Samsung 960 Pro 512GB | WD Gold 10TB | WD Red 4TB X 2 | PSU Corsair AX1500i | Custom Water Loop - RAD MO-RA3 420 Pro | EK Monoblock | Phanteks GPU Block | Heatkiller 200 Tube RES | EK Dual D5 Revo Pumps | 9 X Corsair ML 140 Pro Fans on RAD | | Bitspower Fittings Black Chrome | Cooler Master Cosmos 2 Modded Case | Silent WIngs 3 120mm Intake |
09-18-2020 09:55 PM #4
G75rog PC Specs Motherboard R VI Apex Processor I9-7900X Memory (part number) 64GB Gskill Trident Z Graphics Card #1 AMD Radeon VII EKWB water block Graphics Card #2 Waste of PCI lanes in NVME environment Sound Card Stock Monitor LG 34" Ultra Wide3440x1440 Storage #1 4ea 960 Pro 2TB, 2ea 970 Evo 2TB Storage #2 1ea 960 Pro 1 TB, 1ea 970 Pro 1TB CPU Cooler EKWB CPU, Swiftech Res/pump, 400mm Rad Case Thermaltake View 91 Power Supply NZXT Hale 90 1200W Keyboard Logitech G910 Mouse Razer Ouroboros OS W10 64 1809, 1903, Ubuntu Linux Network Router Netgear R9000 + 4ea R9000 AP's, 10 Gb Switch Accessory #1 Hyper M.2 X16 V2 Accessory #2 10GB network via Intel 550 Nic Accessory #3 2 10GB Asustor NAS 7000 series
- Join Date
- Jan 2013
- Reputation
- 13
- Posts
- 309
A number of companys use this style of plug in battery. Amazon has a wide selection.
I built my system with quick disconnects so any line or part can be removed without water loss.
09-19-2020 11:25 AM #5
MirceaForce PC Specs Motherboard ASUS RAMPAGE VI EXTREME OMEGA Processor Intel® Core i9-7920X Processor Extreme Edition 4.2 GHZ auto Memory (part number) G.SKILL 32GB 14-14-14-34 [Trident Z RGB] F4-3200C14Q-32GTZR Graphics Card #1 NVIDIA GEFORCE GTX 1070 Founders Edition Graphics Card #2 Samsung SSD 850 EVO 2TB Graphics Card #3 Samsung SSD 850 PRO 2TB Sound Card Sound Blaster Z Monitor IPS LED LG 27" 27UD69P 27 inch 4K 5 ms WhiteFreeSync - disabled, Display port Storage #1 Samsung 950 PRO M.2 512GB OS Storage #2 Samsung SSD 850 EVO 2TB CPU Cooler CORSAIR Hydro Series H80i v2 Case Cooler Master: HAF X Power Supply Seasonic PRIME Titanium 850w Keyboard normal usb benq Mouse Razer Taipan Headset/Speakers Logitech Z-5500 digital OS Windows 10 x64 Pro up to date Network Router :Intel® Ethernet Server Adapter I210 Accessory #1 LG OLED55C8PLA
- Join Date
- Oct 2016
- Reputation
- 8
- Posts
- 216
you are true the design is very bad and it's not easy
but they changed this also starting from r6e omega , I think also for encore
Not every battery fail after 3 years , I did own other boards form other brands more then 6 years or so and the cmos battery did not failed me,
I know that if you keep you system power up non stop the battery will remain charged for a very long time .
seems your battery failed much quicker even with system power 24/7MB: ASUS RAMPAGE VI EXTREME-CPU: Intel Core i9-7920X Processor Extreme Edition 4.2 GHZ auto-CORSAIR Hydro Series H80i v2 Video: GEFORCE GTX 1070 Founders Edition. - G.SKILL 32GB 14-14-14-34 [Trident Z RGB] F4-3200C14Q-32GTZR- Seasonic PRIME Titanium 850 w-SSD: Samsung SSD 850 PRO 2TB x3 -SSD: Samsung 950 PRO M.2 512GB OS-Sound Blaster Z -Intel Ethernet Server Adapter I210 CASE:Cooler Master: HAF X MONITOR:IPS LED LG 27" 27UD69P 27 inch 4K 5 ms TV: LG OLED55C8P OS: Windows 10 x64 Pro up to date
09-21-2020 12:04 PM #6
- Join Date
- Sep 2017
- Reputation
- 138
- Posts
- 790
The people who design CMOS battery placement of ROG RAMPAGE VI EXTREME were extreme abnormal.
Even you power on it 24/7 3 years pass , you'll face this issue when CMOS battery runout.
They are abnormal people. I belived.Windows 11 22H2 Build 25179.1000 Core i9 7980XE 02006D05 MCU 2021-11-13 R6E 3701 MODDED BIOS TPM 2.0 Enabled VROC 7.7.0.1054 + RST 18.31.3.5434 ME FW 11.12.92.2222 DV 2211.2.3.0 64GB DDR4 3200 XMP POSEIDON 1080i GTX NVIDIA Driver 525.26 WHQL 3TB SAMSUNG 970 EVO PLUS OMS Driver 18.37.1.1003 WHQL i219 V OROM 0.1.02 BA 0.1.16 12.19.2.45 WHQL AQC 107N FW 3.1.121 AQC 3.1.7.0 WHQL Realtek HD 6.0.9381.1 WHQL SAMSUNG ODYSSEY G9 49 NEO FW 1008 VESA HDR 2000 DP
09-21-2020 03:39 PM #7
- Join Date
- Oct 2016
- Reputation
- 8
- Posts
- 216
03-20-2021 08:15 AM #8
- Join Date
- Jul 2015
- Reputation
- 10
- Posts
- 13
My cmos died today. Do I need to take out the whole motherboard from my casing in order to change it? Are there any screws at the back? Or only front? I'm running custom loop.
03-23-2021 01:17 AM #9
- Join Date
- Feb 2019
- Reputation
- 129
- Posts
- 713
Should Try the one I had to replace in a G752VY laptop. Total disassembly required. Of course I extended it to the drive bay area if I have to get at it again.
05-21-2021 02:08 AM #10
- Join Date
- Oct 2017
- Reputation
- 10
- Posts
- 10
I ran into this problem this week the cmos battery died. I have a custom loop also. I ended up cutting the two wires off the old battery and soldering on a single cr2032 holder and routed it to the outer part of the motherboard on the bottom.
Here is the holder i used: https://www.adafruit.com/product/4856
hope this will help someone
