OMG WHO DESIGN ROG RAMPAGE VI EXTREME CMOS Battery placement!?
restsugavan
86239
Why did ASUS Engineer design CMOS battery placement so badly?
Do you think ROG RAMPAGE VI EXTREME CMOS battery never run out ?
86240
Only one battery replacement need more than 60 min to disassemble the ROG Armor.
86241
Please do not use these method for next ROG RAMPAGE VII EXTREME for Icelake X
or not I will choose other brand instead.
86242
Can’t believe the most expensive mobo also expensive time to replace CMOS battery 🔋
Beware everyone only 3 years battery run out shortly. And you’ll see this experience like me.
W11CANARY 26085.1 Core i9 7980XE 02007006 MCE ME 11.12.95.2499 R6E OFFICIAL BIOS 3801 SAMSUNG OG9 FW 1019.0 SSD 970 EVO PLUS 1 TB x 3 NVIDIA RTX 4090 GAME READY 551.86 64GB GSKILL DDR4 3200MHz JBL 9.1 Sound Bar DTS-X
15 REPLIES 15
cekeu
Level 12
It has been returned to the conventional location on the R6EE so logically they will not do this stupidity again for the R7E
Abaidor
OMG! - That means I need to disassemble my custom loop as well.......
Damn this is going to be a PITA and lots of "cursing"...........
Asus Rampage VI Extreme | i9-7940X | 64GB Trident Z RGB 3600 | Asus Strix 1080Ti OC | Samsung 960 Pro 512GB | WD Gold 10TB | WD Red 4TB X 2 | PSU Corsair AX1500i | Custom Water Loop - RAD MO-RA3 420 Pro | EK Monoblock | Phanteks GPU Block | Heatkiller 200 Tube RES | EK Dual D5 Revo Pumps | 9 X Corsair ML 140 Pro Fans on RAD | | Bitspower Fittings Black Chrome | Cooler Master Cosmos 2 Modded Case | Silent WIngs 3 120mm Intake |
G75rog
A number of companys use this style of plug in battery. Amazon has a wide selection.
I built my system with quick disconnects so any line or part can be removed without water loss.
MirceaForce
Can’t believe the most expensive mobo also expensive time to replace CMOS battery �
you are true the design is very bad and it's not easy
but they changed this also starting from r6e omega , I think also for encore
Not every battery fail after 3 years , I did own other boards form other brands more then 6 years or so and the cmos battery did not failed me,
I know that if you keep you system power up non stop the battery will remain charged for a very long time .
seems your battery failed much quicker even with system power 24/7
MB: ASUS RAMPAGE VI EXTREME-CPU: Intel Core i9-7920X Processor Extreme Edition 4.2 GHZ auto-CORSAIR Hydro Series H80i v2 Video: GEFORCE GTX 1070 Founders Edition. - G.SKILL 32GB 14-14-14-34
F4-3200C14Q-32GTZR- Seasonic PRIME Titanium 850 w-SSD: Samsung SSD 850 PRO 2TB x3 -SSD: Samsung 950 PRO M.2 512GB OS-Sound Blaster Z -Intel Ethernet Server Adapter I210 CASE:Cooler Master: HAF X MONITOR:IPS LED LG 27" 27UD69P 27 inch 4K 5 ms TV: LG OLED55C8P OS: Windows 10 x64 Pro up to date
restsugavan
The people who design CMOS battery placement of ROG RAMPAGE VI EXTREME were extreme abnormal.
Even you power on it 24/7 3 years pass , you'll face this issue when CMOS battery runout.
They are abnormal people. I belived. 😛
you are true about the placement of the battery of r6e
but this is not a rule that the battery will fail after a period of time ...can run out quickly or after very long time more then 3 years
mindwipe
My cmos died today. Do I need to take out the whole motherboard from my casing in order to change it? Are there any screws at the back? Or only front? I'm running custom loop.
BigJohnny
Should Try the one I had to replace in a G752VY laptop. Total disassembly required. Of course I extended it to the drive bay area if I have to get at it again.
bmcbride1991
I ran into this problem this week the cmos battery died. I have a custom loop also. I ended up cutting the two wires off the old battery and soldering on a single cr2032 holder and routed it to the outer part of the motherboard on the bottom.
Here is the holder i used: https://www.adafruit.com/product/4856
hope this will help someone 🙂
