Questions About AI Suite 3
pinkfloyd1173
Level 11
Do I really need to have this on my system?
I control my fans in bios anyways and other than that, I really do not use it at all?
Thanks in advance.
ROG STRIX Z790-E GAMING WIFI II Bios 1002: Intel i7 14900k: CORSAIR DOMINATOR TITANIUM RGB 64GB 6600MHz DDR5: : ASUS ROG STRIX PG38UQ: ROG Strix 4090 OC :2 M.2 990 PRO 2 TB: CORSAIR - AIO CORSAIR LINK H170I LCD : Corsair HX1500I: Corsair 7000D airflow Case: Windows 11 Pro
6 REPLIES 6
Wangeyed
no its garbage bloatware, any asus program/tool is terrible
What would you recommend to use so I can see my cpu temps?
hwinfo64 or open hardware monitor theres loads to pick from
pinkfloyd1173
Level 11
I have Icue, and just noticed that I can check cpu temps there too?
Will try that for now.
Question is there a uninstaller for AI3, that will get rid of it completely?
Thanks in advance.
i think there was a tool to remove it completely, i know unistalling doesnt get rid of everything. and yes icue should be fine for monitoring
pinkfloyd1173
Level 11
Yeah I found it man.
Thank you so much for your advice.
