Crosshair VIII Formula doesn't boot with Trident Z Neo 3600MHZ DOCP/Manual Profile
Q3JLZWQ
I've tried BIOS 1302, 2103, and 2203, neither have booted with the default 3600 DOCP profile, I've tried manually selecting mem profiles and I seem to successfully boot only below 3000MHZ. Anyone else experience that with their Trident Z Neo sticks? "As a side note I've tried these sticks on an intel setup/xmp and it booted just fine...
Edit: Forgot to mention my specs:
3950x
Crosshair Viii Formula
Zotac Amp 2080Ti
Trident Z Neo 64GB 16C
Force 600p NVME
18 REPLIES 18
Baio73
What if you manually set the RAM to 3600MHz?
Are they 4x16 or 2x32Gb? Usually populating all 4 slots brings to major stability issues.
Baio
CASE Lian Li 011D XL CPU AMD Ryzen 7950X3D COOLER Corsair H150i Elite Capellix MOBO Asus ROG Strix X670E-A Gaming Wifi RAM 2x16Gb Corsair Dominator Titanium 6000 [CMP32GX5M2B6000Z30] PSU Asus Thor 1200P VGA Asus ROG Strix RX 6900XT DISPLAY LG 34GK950GF AUDIO Logitech G560 SDD NVMe WD Black SN850 4Tb INPUT Logitech Pro wireless + Powerplay + Corsair MM 700 RGB - Corsair K100
Darox
Make sure ram Voltage 1.35 or 1.40 I use same RAM and play with timing see how board behaves
Baio
4x16GB, board still fails to boot with 2 sticks at 3600MHz, setting them manually does not work either.
Have tried 1.35 with a 0.01 increment on each failed boot, still no success.
Marvin_K_Mooney
yeah some thing is bad with the BIOS i have G.skill 3600CL16 ram and it refuses to boot up if i touch it with voltage or MHZ stuck at 2133Mhz for now i guess until ASUS fixes it.
RedSector73
Level 12
3950x
Zotac Amp 2080Ti
Force 600p NVME
Check you put the RAM is in Slots 2 & 4 from the CPU and then DOCP should work. If your using 4 sitcks than try two in slots suggested. Typically 4 sticks need to be Asus QVL for RAM.
If not, check https://www.amd.com/en/products/ryzen-compatible-memory/ready-for-3rd-gen-amd-ryzen and make sure your RAM is on the AMD official QVL list for RAM.
Ram is QVL'd, tried 2 sticks as I mentioned above that didn't work on either A2-B2 or A1B1
B2 & A2.
F4-3600C16Q-64GTZNC is on the G.skill list, have you tried G.skill support site ?
https://www.gskill.us/forum/
So what happens ?
RedSector73 wrote:
B2 & A2.
So what happens ?
I haven't pinged them yet but I'll be doing so today, as for the slots, I've tried both positions and it wouldn't boot with 3600MHz.
What cooler are you using and did you change the CPU heatsink mounts or back retaining bracket ?
