AURA Not Showing Motherboard or Fans
Exigeous
Using version 1.07.79 v2.1 (as the link to the latest version is broken)
I recall at one point seeing my motherboard in the list of devices but now I only see my Trident Z Ram. Can control it just fine but can't see the motherboard OR the 5 ARGB fans that are connected. They all work and all cycle in sync with each other but are not in sync with the RAM (which again AURA can control).
I've done the following:
- Uninstalled Aura, rebooted
- Go to BIOS disable all lighting
- Power off (and lights shut off fine)
- Go to BIOS and re-enable all lighting
- Power off (Fans/RAM turn off, motherboard lighting does not unless I switch off the PSU)
- Reinstalled Aura, rebooted
And still I only get the RAM listed in Aura. I have the 5 fans connected via a 5 way splitter that came with the fans (part of a Coolermaster AIO kit) to the ARGB header at the top of the board. Again they cycle perfectly with the motherboard lights but do NOT show in Aura so I can't control them.
Ideas?
Exigeous
BUMP - anyone??
hmm .. got the exact same problem. (in my case I only see the graphics card .. but not the mainboard or the attached fans) Did you find a solution?
Nope, not at all. Mulitple reboots, reinstall, different header on board, reattach everything and nada.
