Results 1 to 3 of 3
    ROG Member Array
    Jul 2018
    23
    B550-E: audio driver 6.0.8971.1 can't be installed & Razer Viper doesn't work in UEFI
    Hey ASUS,
    The latest audio driver (6.0.8971.1) from the mobo's website page can't be installed, as per the screenshot. Also, the Razer Viper mouse doesn't work in the UEFI -- the cursor doesn't move.
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD NVMe Samsung 970 EVO Plus 500GB
    Storage #2SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Headset/Speakers Logitech Z333
    OS Windows 11 Pro 64 bit 21H2/CO/22000
    MoKiChU's Avatar
    Aug 2013
    404
    671
    Quote Originally Posted by loinad View Post
    Hey ASUS,
    ASUS made a mistake, the latest drivers package available on your support page is not for your motherboard but for ASUS PRIME/TUF DTS Custom motherboards.
    You have an ASUS ROG SS3|DTS Sound Unbound motherboard, so :
    You need Realtek Audio Drivers (UAD - ASUS ROG SS3-DTS MB) from the first post of this thread.
    Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
    ROG Member Array
    Jul 2018
    23
    Quote Originally Posted by MoKiChU View Post
    ASUS made a mistake, the latest drivers package available on your support page is not for you motherboard but for ASUS PRIME/TUF DTS Custom motherboards.
    Thank you -- I always appreciated your packaging work and will once again use your drivers. Glad to see you back at it.
