Results 1 to 3 of 3
    amitgedia Array amitgedia PC Specs
    amitgedia PC Specs
    Motherboardasus rampage v
    Processori7 5820K
    Memory (part number)Corsair Vengance 4x4GB
    Graphics Card #1Nvidia Quadro 600
    MonitorLG Flatron E2360
    CPU CoolerCorsair H110i
    Casecoolermaster HAF 932
    Power Supplycoolermaster 700W
    Keyboard Microsoft
    Mouse Logitech
    Headset Philips SBH 4000
    Mouse Pad Intel Extreme
    OS Win 7 64 bit
    Network RouterMTNL DM 856W
    Nov 2015
    32
    33
    RAM info required asap
    I have an Asus Rampage V Extreme mobo and intel i7 5820k processor
    I want to upgrade my RAM to 32 GB and i was searching the corsair website and was interested in buying -
    "SKU CMK16GX4M1D3000C16
    VENGEANCE® LPX 16GB (1 x 16GB) DDR4 DRAM 3000MHz C16 Memory Kit - Black"
    I just wanted to know whether this RAM will be compatible with my mobo and processor and there will be no issues using it
    Need help asap as i want to order it at the earliest
    Thanks
    Amit
    ROG Guru: Orange Belt Array xmanrigger PC Specs
    xmanrigger PC Specs
    MotherboardAsus ROG Strix Z490-A
    ProcessorIntel i9-10850
    Memory (part number)F4-4000C15D-16GTRS
    Graphics Card #1EVGA RTX 2070 Super /HeatKiller IV
    Sound CardO/B
    MonitorLG 32GK650F-B
    Storage #1WD Black 1TB M.2
    CPU Coolerwatercool Heatkiller Rev.3.0
    CaseLian Li O1 Dynamic
    Power SupplyCorsair AX1200i
    Keyboard Logitech G15
    Mouse Logitech G502 Hero
    Headset/Speakers logiteck Z-5500 5.1
    OS Win10 Pro 64
    Mar 2012
    30
    257
    Quote Originally Posted by amitgedia View Post
    Thanks
    Amit
    Sounds like you currently have 16GB installed (should be Quad Channel). How many sticks? The memory you describe is only dual channel. You want Quad channel. Plus, this memory is not listed in your mobos QVL.
    It may run on your PC, but in dual channel only. You will want a 2 stick kit. Then all memory will run in dual channel only. If I am correct, if you add just another single stick to your current config, all your memory would be knocked down to single channel mode. What I would suggest is to try and find another identical Quad Channel 16GB memory kit as the one you have. Optimal would be buying a 32GB Quad Channel Memory Kit.
    GUTS: ROG Strix Z490-A / i9-10850 / 16GB G.Skill TridentZ Royal 4000mhz / WD Black 1TB M.2 / EVGA RTX 2070 Super / Corsair AX1200i PSU / Lian Li o1 Dynamic
    WATER: Watercool HeatKiller - CPU / Watercool HeatKiller IV - GPU / 2X 360 Radiators / XSPC Photon Rez / D5 Pump / DISTILLED WATER + Silver Coil
    Moderator Array
    Jul 2016
    12
    218
    Hi Amit,
    Here's the QVL:
    https://dlcdnets.asus.com/pub/ASUS/m...me/R5E_QVL.pdf
    It looks like it's not listed on it. It may work, but you may run into issues.
