Results 1 to 10 of 10
    ROG Guru: Yellow Belt Array AnonGhost PC Specs
    AnonGhost PC Specs
    MotherboardASUS ROG STRIX Z370-E GAMING
    ProcessorINTEL CORE I5 - 8600K
    Memory (part number)Trident Z RGB DDR4-3600MHz CL18-22-22-42 1.35V 16GB
    Graphics Card #1ASUS STRIX-GTX970-DC2OC-4GD5
    MonitorTCL 4K HDR10 TV
    Storage #1WDC WDS256G1X0C
    Storage #2TOSHIBA DT01ACA050
    CPU CoolerThermaltake Floe Riing RGB 240 TT Premium Edition
    CaseTHERMALTAKE OVERSEER RX-I
    Power SupplyEVGA SuperNOVA 850 G2 850W 80+ GOLD
    Keyboard Corsair Strafe RGB
    OS WINDOWS 10 PRO VER 2004 (OS BUILD 19041.508
    Jul 2016
    49
    185
    HELP ME with RGB on motherboard
    hello everyone
    i have asus rog strix z370e gaming motherboard and rgb light not working also i have rgb strip and if i connect strip to rgb header on mb also not working but if i connect strip via molex connector rgb strip works so can someone help me?
    MB: ASUS ROG STRIX Z370E - GAMING
    CPU: INTEL CORE I5 - 8600K
    CPU COOLER: Thermaltake Floe Riing RGB 240 TT Premium Edition
    GPU: ASUS STRIX GEFORCE GTX 970 OC
    RAM: 16GB - 2x8GB G.SKILL Trident Z RGB DDR4-3600MHz CL18-22-22-42 1.35V
    16GB (2x8GB)
    PSU: EVGA SuperNOVA 850 G2 850W 80+ GOLD
    New ROGer Array Jesseinsf PC Specs
    Jesseinsf PC Specs
    MotherboardASUS ROG Maximus XI Extreme (Z390)
    ProcessorIntel Core i9 9900K
    Memory (part number)Corsair CMW128GX4M4E3200C16
    Graphics Card #1NVIDIA - GeForce RTX 2080 Ti FE
    Sound CardCreative Labs Sound Blaster AE-9
    MonitorSamsung 32" UH750 QLED UHD Monitor
    Storage #1Samsung 970 Pro M.2 PCIe SSD 1TB
    CPU CoolerCooler Master MLX-D36M-A20PC-R1 w/ Noctua NF-F12 industrialPPC-2000 IP67 PWM x3 Fans
    CaseLian Li PC-011 Dynamic XL (ROG Certified)
    Power SupplyCooler Master V1200 Platinum
    Keyboard RAZER HUNTSMAN ELITE - LINEAR OPTICAL SWITCH (Red) w/ PBT Keycaps
    Mouse Razer Basilisk Ultimate with Charging Dock
    Headset Bowers and Wilkins P9 Signature
    Mouse Pad Razer Vespula V2 Mousepad
    Headset/Speakers Creative GigaWorks T40 Series II
    OS Windows 10 Pro for Workstations
    Network RouterROG Rapture GT-AC5300
    Accessory #1 Microsoft Xbox Elite Wireless Controller Series 2
    Accessory #2 Logitech BRIO ULTRA HD PRO WEBCAM
    Jesseinsf's Avatar
    Mar 2019
    22
    218
    Quote Originally Posted by AnonGhost View Post
    hello everyone
    That happened to me a few times. Shutting down the PC and turning off the power supply for 10 seconds seemed to work for me.
    AnonGhost PC Specs
    Jul 2016
    49
    185
    i try different ways but still not work
    i try install other versions of windows 10(right now win 10 ver 2004)
    i'm try use other psus but not help
    i don't know what is wrong
    maybe it's trouble of bios?current version of bios 2401
    i dont know how to flash older versions of bios
    16GB (2x8GB)
    Jesseinsf PC Specs
    Jesseinsf's Avatar
    Mar 2019
    22
    218
    Before Windows (like when you turn on your PC), does all RGB devices turn on then turn off when Windows starts?
    AnonGhost PC Specs
    Jul 2016
    49
    185
    i have ram with rgb and aio cooling system with rgb and both works normally
    16GB (2x8GB)
    ROG Enthusiast Array
    Dec 2013
    14
    54
    What software do you have installed to control the motherboards RGB?
    When I had it were there was no RGB I installed Aura and it worked again.
    https://www.asus.com/campaign/aura/us/download.php
  7. #7
    AnonGhost PC Specs
    Jul 2016
    49
    185
    Quote Originally Posted by bscool View Post
    i try almost all versions of asus aura then aura creator then corsair icue but still not working and no need software to working onboard rgb lighting becose onboard rgb lighting enbaled in bios but in my case not working try check onboard light strip with battery and strip works i don't know what i must to do i have on board 2 rgb headers and 1 adressable header i try check all of them but now working
    16GB (2x8GB)
  8. #8
    Dec 2013
    14
    54
    So you have them working now? If so what did you do to get them working?
  9. #9
    Dec 2013
    14
    54
    I can tell you that just because the bios say LED enabled does not mean they will work. For example if I set the LEDs in software to off and unstill the software the LEDS will not work even though they are enabled in BIOS.
    Also Corsair says you need them. From the page "Notes:CORSAIR iCUE version 3.26 and ASUS Aura Sync Utility version 1.07.79 are required."
    But if you said you have tried them and they didn't work your MB must be defective. https://www.youtube.com/watch?v=C9tz1-fdlKo
    I have had 5 z390 and z490 Asus board and they all work like this. Unless z370 is different, but I doubt it is.
    The LED has a separate storage/firmware area which will store/control settings and the software is needed to get full functionality and is not possible to access via the bios. If the software was not needed they would be fully adjustable as in color, strobing etc in the BIOS like some motherboards can do.
    As an example on this current build I did for someone using a z490 Hero I installed the Aura software and set the MB LEDs to white and then uninstalled the software and now the LEDs will stay white even if I reinstall windows and do not install any Aura software.
  10. #10
    AnonGhost PC Specs
    Jul 2016
    49
    185
    all my rgb led strips work perfect i i connect them via molex coonector but if i try connect to rgb and adressable header on MB strips not lighting also i check onboard rgb strip via battery power so leds not defective
    16GB (2x8GB)
