ArmouryCrate.UserSessionHelper.exe infinite CPU usage
fivetech
Hi all,
I have G731GW laptop.
After the latest update of ASUS System Control Interface V2.2.28.0, when I check task manager, I see there is a process ArmouryCrate.UserSessionHelper.exe which keeps my CPU loaded by 13 percentage always. System reboot did not solve the problem. 😞
6 REPLIES 6
darix84
fivetech wrote:
Hi all,
Estoy igual que tu, el proceso consumo mucha CPU. Alguna solucion?
Same problem here
86342
Open the ARMOURY CRATE UWP, and then close it. After that, end task "ARMOURT CRATE User Helper Session" in Task Manager.
Yeah, i can confirm this problem is still here. It seems to appear after a recent update, i bought my G17 G712LWS-EV0035 just a month ago, and there was no this problem before. Well, I can open task manager and finish this process, and then it reappears with 0% cpu usage, but after every Windows reboot I need to do this again. Seriously, this software problem needs to be fixed, its really annoying, also, fans in idle became a more noisy than before, cuz of cpu usage...
Hello everyone! I have same issue on Zephyrus GX701 GWR proccess ArmoryCrate in idle uses high CPU 13-15%. I found solution on Reddit:
In Game Library (1) Pick kinda options (2) and uncheck "Auto Scan Games" (3). Restart PC or proccess
Hope it hepls:)
86440
srsbsns
Same problem here
