g75vx replace GeForce® GTX 670MX with 3GB GDDR5 VRAM
ToniStark
Hello.
I have an old ASUS ROG g75vx
graphics card went bad: NVIDIA® GeForce® GTX 670MX with 3GB GDDR5 VRAM
i am looking to buy a new one but then it comes the doubt is it possible to upgrade to a newer model?
thanks in advance for your comments and time.
Hola, tengo una Asus Rog g75vx
mi tarjeta grafica ha fallado y estoy en aras de reemplazarla; la tarjeta que tiene es: NVIDIA® GeForce® GTX 670MX with 3GB GDDR5 VRAM
y me ha surgido la duda si es posible hacer un upgrade y poner alguna mejor en lugar de comprar la misma.
gracias de antemano por sus comentarios y su tiempo.
xeromist
I moved your thread over to the main g series forum. It will get read here.
I personally wouldn't try to upgrade a machine that old. The cooling is custom to that card and parts tend to be too expensive for the performance anyway. If you can get a matching replacement graphics card for cheap on ebay then that might be worth fixing.
