RYUO 240 - Pump doesn't work?
sergedsd
Hello everybody,
I just received a Ruyo 240 and I am very disappointed. The cooling performance doesn't seem very good, like my old Be Quiet Pure Rock but with more noise. But I think there is a problem with the pump. Maybe I am wrong and need some confirmation or some help.
1 - I don't see pump information in the bios
86385
2 - When I want see pump information on the oled screen. I have just 0rpm (AIO pump, W_pump)
86386
3 - My 4 pin connector is plug on CPU_fan but if I try to plug it on AIO_Pump I can't boot and i have a massage " CPU Fan error"
The fans seem to be working fine.
Any suggestion will be welcome 😉
Thank you!
ASUS ROG STRIX Z390-F GAMING
I7 9700k
Win10
alexmihaila
Pump speed is not available on UEFI/BIOS; those are speeds for anything connected to respective fan headers;
to see pump speed use an utility like aida64 or hwinfo64.
You can not control pump speed, its always 100% and its fed from sata power connector.
You shall connect 4 pin to CPU fan header, it will show radiator fan speed, that you can control from UEFI/BIOS or win10; if you connect to any pump header it will stay at 100%
If you still want to connect to AIO pump header, select CPU fan monitoring to ignore in UEFI
Performance is on par with best air cooled CPU coolers; one thing though, i had to replace original thermal paste (which was dry) on waterblock with better one.
Hope it helps
Thank you alexmihaila for your helpful answer 🙂
I have try both : CPU fan header and AIO pump header (with CPU fan monitoring to ignore in UEFI). OK I can monitoring fan speed or AIO pump speed.
With the AIO pump header, I can change, in BIOS, AIO pump speed to 90% for example (good idea?).
I will try hwinfo64 for a better monitoring.
