GL504GW Panel Overdrive Not Working
mattpunx90
Another of the tons of software issues i face within this device. Already installed Refreshrate service. The 2 versions i could find, nothing.
It just get stuck on "starting" at services tab.
At Armoury Crate the option is greyed and not available
Blake1
Hello mattpunx90,
How is the issue now?
If the issue still persist, please PM me your SN.
Thank you very much.
Blake@ROG wrote:
Hello mattpunx90,
Hi Blake, and thanx for your answer. I could fix the problem, even though it cost me a huge headache.
Apparently the service for Panel Overdrive wasn't working and unable to even start running. So i had to fully reinstall everything (can't quite remember how exactly i did proceed) and then was able at last to make it run properly.
But in other topic, i'm still having several issues with audio going out of sync after a while using the only driver that Asus provides to this device (Realtek 6.0.1.8639). Already tried another one other user provided me on another thread, but was no case. The only driver upgrade that's provided by Driver Booster works for that matter but it isn't compatible with Realtek Audio Console and cause headphones not to work or being recognized when plugged in.
Can you provide me any kind of solution?
