Results 1 to 2 of 2
    New ROGer Array
    Oct 2019
    3
    Front ARGB Fans - Only 1 LED on when synced?
    I have an Asus Crosshair Hero VIII WiFi...
    I have a CoolerMaster H500M with front CoolerMaster ARGB lights.
    Only one of the LEDs work when on Rainbow effect on each fan. If I unsync addressable header, all the lights work on each fan.
    If I choose a static color, all the lights work on each fan. I tried "reset to default" and still same issue.
    I think I had this once before, and magically a day later without rebooting, or changing anything it fixed itself. Not sure if it will this time.
    Has anyone come across this? Any way to fix? Thanks.
    Item Version
    Armoury Crate UWP App 3.1.6.0
    ROG Live Service 1.1.6.0
    AURA Service (Lighting Service) 3.04.22
    Armoury Crate lite service 3.1.5
    ASUS AIOFan HAL 1.1.14
    ASUS AURA Extension Card HAL 1.0.24
    ASUS AURA Motherboard HAL 1.0.68.0
    ASUS AURA Odd Component 1.0.8
    ASUS MB Peripheral Products 1.0.31
    AacDispaly 1.1.25
    AacVGA 0.0.3.0
    CosairDram 1.0.13
    KingstonDram 1.0.27
    AURA DRAM Component 1.0.53
    ENE RGB HAL 1.1.26.1
    ENE_DRAM_RGB_AURA42 1.00.02
    ENE_EHD_ASM_HAL 1.00.00
    ENE_EHD_M2_HAL 1.00.02
    ENE_QSI_Azeroth_HAL 1.0.9.0
    GALAX GAMER RGB 1.00.02
    PHISON HAL 1.0.2.0
    Patriot Viper DRAM RGB 1.0.9.1
    Patriot Viper M2 SSD RGB 1.0.5.1
    New ROGer Array
    Oct 2019
    3
    Ok, I fixed it...
    In Armory Crate, go to the top left option "Device" (Looks like icon of mouse and keyboard).
    Then go to "Addressable Headers" tab on the top.
    There you will see Strip options with Number of LEDs. Both mine were set at 120.
    So, I changed the number of LEDs to 60 on the header I was using, and it started working again. I then changed it back to 120, it applied the setting, and it still works normally.
    So whatever this did reset things to work again even though the setting isn't changed at all. Hope that helps someone.
