Results 1 to 4 of 4
    New ROGer Array 8eofilos PC Specs
    8eofilos PC Specs
    MotherboardROG Strix X570-E Gaming
    ProcessorAMD 3900X
    Memory (part number)GSkill Ripjaws RGB 64GB 3600MHz
    Graphics Card #1Gigabyte 1050 Ti 4GB OC Windforge
    Sound CardFocusrite 2i2
    MonitorASUS VA325H
    Storage #1Samsung M.2 NVM2 1 TB 970 EVO Plus
    Storage #22 X SSD 850 EVO 500 GB
    CPU CoolerCorsair H110i
    CaseV71 Thermaltake
    Power SupplyThermaltake RGB 850 W
    Keyboard Corsair K70 Lux Blue
    Mouse Talon Blue by Thermaltake
    Headset Audio-Technica ATH M40x
    Mouse Pad Inland RGB Gaming Mouspad
    Headset/Speakers Speakers Creative
    OS Windows 10 Professional 64 bit
    Sep 2020
    3
    Error Code or not? Voltage max?
    I have overclocked the CPU to all cores at 4.3 GHz Stable and the voltage is set with offset to 1.288 in the BIOS. The Hardware info is giving me sometimes
    1.3 Volts. The Ram is running at 3600 MHz. The PC is working fine, but I see this 0C on the motherboard Display and do not know if it is a problem. The Motherboard is less than a month old as well as the RAM, CPU, M.2 NVMe and Power Supply. The SSD's and the SATA HDD Drives and the Graphics Card are from my old build. My temps never go above 70-71C when rendering. Idle it goes from High 20s to Mid 30s. Normal work is always under 60C. I have memtest-ed my RAM and Prime95 my CPU and everything is stable. I actually have tested it at 1.325V all core 4.4GHz and it worked fine and passed 8000 Points in Cinebench. But I was reading that the 3900X shouldn't run over 1.3 V all core because it will degrade it, even though my Temps never passed 78C on heavy workloads, so I backed it down to the 4.3GHz and I am pretty happy about the stability of the system while running all this programs at once. All the above I did with only adjusting the offset values and the Ram clock to 3600MHz with DOCP
    Should I worry, is there something I am missing? Can anyone tell me really what the max voltage for 3900x is safe for all cores?
    Thanks
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    166
    2,109
    1.3v -1.35v is ok if not running heavy AVX workloads. For a gaming system, these manual voltages are fine on this platform. You can experiment with per CCX overclock if wanting to explore higher frequencies on the stronger chiplets.
    If planning on running heavy workloads such as encoding or other AVX heavy tasks, I would recommend leaving the system to overclock itself either with PBO enabled or disabled.
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,690
    Quote Originally Posted by 8eofilos View Post
    That is normal...it shows OC when you OC
    8eofilos PC Specs
    ProcessorAMD 3900X
    MonitorASUS VA325H
    CaseV71 Thermaltake
    Sep 2020
    3
    Quote Originally Posted by Silent Scone@ASUS View Post
    I am not familiar yet with the CCX method. The auto overclock I did with AMD Overdrive wasn't that great. It got some cores working at 4.7 and 4.8 but the performance when doing rendering was very poor. The manual 4.3, 4.4 GHz were best
