Results 1 to 10 of 13
Thread: GL504GW Audio Out of Sync
10-08-2020 02:15 AM #1
Another software issue on this device. Now Realtek audio driver version 6.0.1.8639 (the only one provided by Asus at it's website and the only one that works) it's causing audio to go out of sync on every video playback after a few minutes.
Already reinstalled the driver and it ends up doing the same thing each and every time and other drivers cause total lose of audio, or headphones jack stop working at all.
10-08-2020 06:42 AM #2
MoKiChU PC Specs Motherboard ASUS ROG Strix Z370-F Gaming Processor Intel Core i7-8700K Memory (part number) Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB) Graphics Card #1 ASUS ROG Strix GTX 1080 Ti OC Monitor ASUS ROG Strix XG35VQ Storage #1 SSD NVMe Samsung 970 EVO Plus 500GB Storage #2 SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB CPU Cooler Cooler Master ML240L RGB Case BitFenix Enso Power Supply Corsair TX850M (850W) Keyboard Logitech G413 Mouse Logitech G502 Headset/Speakers Logitech Z333 OS Windows 11 Pro 22H2
- Join Date
- Aug 2013
- Reputation
- 460
- Posts
- 689
You have an ASUS ROG SS3 notebook, so :
You need Realtek Audio Drivers (UAD - ASUS ROG SS3 NB) from the first post of this thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.Last edited by MoKiChU; 11-25-2021 at 08:56 AM.
10-09-2020 01:08 AM #3
10-09-2020 09:18 AM #4
- Join Date
- Aug 2013
- Reputation
- 460
- Posts
- 689
10-10-2020 01:13 AM #5
10-17-2020 02:39 AM #6
Well, i followed all the steps and installed it ok. But, audio out of sync issue continues to happen anyways even with this driver
11-28-2020 04:41 AM #7
Just posting to avoid this thread to die forgotten. The issue is still there and can't be solved, and it's getting pretty anoying.
If someone could bring a new solution to this problem, i would be grateful
12-28-2020 06:34 AM #8
- Join Date
- Feb 2019
- Reputation
- 15
- Posts
- 920
Hello mattpunx90,
May I have an audio or video record of the issue?
02-06-2021 08:56 PM #9
02-12-2021 05:46 AM #10
https://drive.google.com/file/d/1xO7...ew?usp=sharing
Audio goes progressively out of sync on time and gets more noticeable after 20 minutes of playing
