10-16-2020 01:24 PM - last edited on 03-05-2024 07:35 PM by ROGBot
10-16-2020 04:05 PM
handokovska wrote:
the ssd comes with 128 Gb n already full now.. i get a 1 TB m2 2280 and already create a drive backup n boot disk...
problem comes when trying to unscrew m2 screw , it cannot unscrew.. already try using rubber, make it hot using solder, no result...
start to think using brute force... any ideas?
10-18-2020 04:26 AM
10-23-2020 06:21 AM
10-26-2020 03:37 PM
10-26-2020 04:32 PM
unforgivun wrote:
cant remember if i read it in the WD version of acronis true image or saw it on video, but basically it said that you need to have the new M.2 installed in the board/system before or you will not be able to boot from it. so you need to put the 128g on usb the 1t in the slot formatted and then run the clone software. hope this helps
10-27-2020 02:25 AM
10-27-2020 02:21 AM
