Results 11 to 18 of 18
11-12-2020 07:02 PM #11
- Join Date
- May 2012
- Reputation
- 10
- Posts
- 71
OOPS! I made a mistake in reporting what I was seeing. I THOUGHT I was at DDR 3600 because I was reading HWinfo and AIDA. But ACTUALLY, I was at 1066-> 2133!
I explicitly set speed to 16-16-3200 at 1.35 v and it would not post!Intel 3770K 4.4ghz, 1.24v. . . . . . . . . . . . . .Intel 4930k 4.7ghz 1.37v
32 gGSkill DR3Trident 2400mhz 1.65v. . . .32 g 1866 Vengeance Pro
ASUS M5G. Noctua D14. . . . . . . . . . . . . . . H110. Noctua A14x4
prime95 stable 78degrees. . . . . . . . . . . . . IBT 75 degrees
OCZ V4 OS. . . . . . . . . . . . . . . . . . . . . . . . . EVO 1TB
Seasonic 700w. . . . . . . . . . . . . . . . . . . . . .1200AX
All tucked into Lian Li A05. . . . . . . . . . . . . .Fractal Midiv2
11-12-2020 10:24 PM #12
- Join Date
- May 2012
- Reputation
- 10
- Posts
- 71
see my post above. I moved them to the other slots
17-17-17-38 @ DDR 4266
AIDA Read 61262 Write 64087 Copy 58730 Latency 41.6nsIntel 3770K 4.4ghz, 1.24v. . . . . . . . . . . . . .Intel 4930k 4.7ghz 1.37v
11-14-2020 08:03 PM #13
lassek PC Specs Motherboard Strix Z490-E Gaming Processor Intel 10900K Memory (part number) F4-3600C16D-32GTZNC Graphics Card #1 Nvidia 2080 Ti Founders Edition Sound Card Creative AE-5 Monitor Samsung SE790 34" 3440x1440 Storage #1 Samsung 960 EVO 250 GB Storage #2 4 x Samsung 500 GB Raid 0 CPU Cooler Watercooled Case Be Queit Dark Base Pro 9 Power Supply Corsair HMX-1000 Keyboard Logitech G815 Mouse Logitech G502SE Headset Logitech G615 Mouse Pad Corsair MM800 RGB Headset/Speakers Logitech Surround Z906 OS Windows 10 - 64 Bit
- Join Date
- Dec 2011
- Reputation
- 10
- Posts
- 63
I dont quite understand? Yut get into BIOS .. chose XMP 2 .. then goes back to AUTO? and set manual 3600 mhz? or what? won the AUTO just default to 2133 mhz?
And did you actually get them down on CAS15? sounds crazy at 3600 ?
Please explain in detail, sorry for not understanding.. thanks.
11-14-2020 08:34 PM #14
- Join Date
- Dec 2011
- Reputation
- 10
- Posts
- 63
11-15-2020 01:32 PM #15
- Join Date
- May 2012
- Reputation
- 10
- Posts
- 71
I had them in slots A1 and B1. Got them to 12-12-12-33 at DDR 3000.
11-17-2020 04:46 PM #16
- Join Date
- Dec 2011
- Reputation
- 10
- Posts
- 63
All rigth.. I guess ill have to settle at 3333 mhz... the difference between that and 3600 is basically nothing but its just a principle for me! that buying something that dosent work as advertised..
sigh!
04-06-2021 11:30 AM #17
- Join Date
- Dec 2011
- Reputation
- 10
- Posts
- 63
UPDATE: Some BIOS updates later and some more tweaking my absolut max stable is now:
3500 Mhz 15-15-15-36 @ 1.4 v VCCIO 1.15v SA 1.2v I can live with that! This is 100% stable ..... Its a shame the last 100Mhz simply wont deliver!I tried everything! 19-19-19-39 timings and 1.5 v no luck.. also messed with high SA og VCCIO no luck..
The RAM is default 3600 Mhz 16-16-16-36 @ 1.35v. But my best result is 3500 Mhz.
Does anyone know of any other RAM settings that can be tweaked for RAM that wont perfom?! The Asus bios has 1000 settings! ..Last edited by lassek; 04-08-2021 at 03:59 PM.
Today 04:14 AM #18
- Join Date
- Mar 2021
- Reputation
- 10
- Posts
- 7
It just happens that I am using the same DRAM stick in my AMD mobo.
My suggestion is to use AIDA or other app to read out the whole XMP profile and compare that with the parameters in your BIOS. Sometimes, the BIOS auto setting of some parameters are quite "aggressive" and may make your system unstable.
For my DRAM at 3600MHz, the XMP profile is:
@ 1801 MHz 16-16-16-36 (CL-RCD-RP-RAS) / 52-631-469-289-9-4-44 (RC-RFC1-RFC2-RFC4-RRDL-RRDS-FAW) (from AIDA)
BTW, I am running my RAM at 4000MHz, all stable!
Hope this helps.Last edited by isaactwn; Today at 04:16 AM.
