Results 1 to 3 of 3
Thread: Slow Speeds on newer firmware
10-24-2020 02:28 PM #1
420Assassin PC Specs Motherboard Maximus IV Extreme-Z (LGA1155) Processor i7 2600K Memory (part number) F3-17000CL9-4GBSRx4 Graphics Card #1 ROG-STRIX-RTX2070-O8G-GAMING Monitor VG248QE Storage #1 Samsung SSD 840 EVO 1TB Storage #2 HGST HDN726060ALE614 CPU Cooler GeminII 2x120mm Case Antec DF-85 Black Steel Power Supply Seasonic Prime Ultra 750 Titanium Keyboard Logitech G910 Mouse Logitech G502 Headset Turtle Beach DX11 OS Win10 Pro Network Router RT-AC88U
- Join Date
- May 2012
- Reputation
- 10
- Posts
- 7
Network Topology
FTTH Connection to ONT in basement
Speeds 1000Mbps Download and 750Mbps Upload.
RT-AC88U connects to ONT with cat6 cable.
Desktop connects to router Cat6
On older firmware 384.45xx entire network has access to full Gig speeds, usually test from fast.com at 800-900Mbps.
Ever since that firmware speeds drop down to 200-300Mbps for all devices on network. Wired and wireless.
Narrowed it down to be QoS bandwidth Limiter being enabled for some devices was the cause. On the newer firmwares if i disable that feature and manually reboot router full speeds return. If i re enable it speeds drop for the entire network, not just the devices set to have limited bandwidth.
Im currently talking to Asus try get resolved, have been for last 2months now.
Currently on their beta firmware version 3.0.0.4.386_39058 and issue remains.
They have most recently tried saying Nat Acceleration was the cause but its not confirmed by disabling it and rebooting router but speeds still slow..
see most recent responce below...
Please see the response from our R&D Team below.
After detailed review of this issue, we have found that the root cause is the conflict of whether process packet recognition.
To achieve the function of the Bandwidth Limiter, which in needs of recognition of each packet to throttle bandwidth. While NAT accelerator is a mechanism to speed up packet transition via by-passing the recognition process. Therefore, the two functions are conflicted in the process of packet recognition, users may only choose one function at a time.
They have also tried saying this is just how bandwidth limiter works, also not true bandwodth limiter should only effect decices set to have limited bandwidth and the rest of the network shoudl remain as normal unrestricted.
If i downgrade to older firmware anything from this version or earlier 384.45xx everything is fine with bandwidth limiter enabled and all but if update to anything newer than that and network wide slow speeds 60% loss..
Has anyone else had this issue or if you have the speeds close to mine can you replicate it?
12-12-2020 06:02 PM #2
- Join Date
- Dec 2020
- Reputation
- 10
- Posts
- 1
Same situation
Same situation here.
Network Topology
FTTH Connection to ONT in "Data Closet"
1 Gbps download and upload speed
RT-AC86U connects to ONT with CAT6 as AiMesh router
Another RT-AC86U and RT-AC68U as 2 AiMesh nodes
After the upgrade to 3.0.0.4.386.40451, my wired speed was throttled at 400 Mbps DL and UL. After removing bandwidth limiter, it is back to 1 Gbps DL and UL.
However, wireless speed is horrible, only at ~40 Mbps or even less, within a few feet away from the main router. Any idea?
12-12-2020 07:33 PM #3
- Join Date
- May 2012
- Reputation
- 10
- Posts
- 7
After talking to Asus tech support. Guess on earlier versions Bandwidth Limiter and NAT Acceleration were not working correctly, when one is on the other is suppose to turn off. NAT Accellerator is needed to get close to the 1Gig speeds. I was able to get asus to write me a modded firmware with both enabled same time (when normally only 1 should be allowed on at a time) and so far all been working perfect for me on the new firmware they wrote me.
