Results 1 to 9 of 9
10-26-2020 11:15 AM #1
Super Gnome PC Specs Motherboard ROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula Processor Intel® Core™ i9-9980XE / AMD 3950x Memory (part number) Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH Graphics Card #1 Asus 2080 Turbo / Asus 2080 ti Turbo Graphics Card #2 Asus 2080 Turbo / Asus 2080 ti Turbo Monitor JAPANNEXT JN-VT500UHD 4K 50-inch LCD Storage #1 Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500 Storage #2 Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2 CPU Cooler ROG Ryujin 360 / NZXT Kraken X62 Case Thermaltake View 71 TG / Thermaltake View 31 Power Supply CORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2 Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
- Join Date
- Mar 2019
- Reputation
- 28
- Posts
- 394
Crosshair VIII Formula Sudden Shutdown --Bios 2311 Related?
While playing a video the system just suddenly powered itself down. The screen went blank, the fans stopped, and nothing.
And in the event viewer there was absolutely nothing about it, but this:
The previous system shutdown at 7:45:48 PM on 10/26/2020 was unexpected.
Could this be because of the latest, very new Bios, or the new AMD chipset drivers?
Usually when this kind of thing happens you see something about it in the event viewer, but here, squat.
Any thoughts anyone? Thanks in advance for any input or thoughts.
This was the first time, and should it happen again, I will post here again.
10-26-2020 11:30 AM #2
Baio73 PC Specs Motherboard Asus ROG Crosshair VIII Formula 2701 beta Processor AMD Ryzen 3900XT Memory (part number) 4x8 G.Skill F4-4000C17D-16GTZR Graphics Card #1 Sapphire RX 5700 XT Monitor LG 34GK950F Storage #1 Samsung 980PRO nVme 512Gb Storage #2 ADATA SX8200PNP NVMe 2Tb CPU Cooler Corsair H150i Pro RGB Case Lian Li 011D XL Power Supply Corsair AX860i Keyboard Logitech G513 Mouse Logitech G903 + Powerplay Headset G933 Artemis Spectrum Mouse Pad Logitech G840 XL Headset/Speakers Logitech G560 OS Windows 10 64bit Network Router Lynksys EA6500 Accessory #1 Corsair Commander Pro Accessory #2 10xCorsair QL120 RGB fan
- Join Date
- Jul 2014
- Reputation
- 11
- Posts
- 148
Usually sudden shutdowns are related to CPU temps or PSU failures.
Can you list your complete configuration?
BaioCASE Lian Li 011D XL CPU AMD Ryzen 3900XT COOLER Corsair H150i Pro RGB MOBO Asus ROG Crosshair VIII Formula RAM 4x8 G.Skill F4-4000C17D-16GTZR PSU Corsair AX860i VGA Sapphire RX 5700 XT DISPLAY LG 34GK950GF AUDIO Logitech G560 SDD Samsung 970PRO NVVe 512Gb - ADATA SX8200PNP NVMe 2Tb NPUT Logitech G903 + Powerplay - G513
10-26-2020 01:05 PM #3
- Join Date
- Mar 2019
- Reputation
- 28
- Posts
- 394
My CPU temps never go above 68 C with a 3950x and Kraken x62. Also, I do have two 2080ti cards in SLI, but my PSU is a 1200 watt one, which should be more than enough to power the whole system. Also, the demands of playing back a video are very low, and I have done much more demanding tasks for hours with no problems. The system is now six months old and this has never happened before--and even when the ambient temperature here was in the 30s C, as high as 35 C for hours, and with it now in the low 20s.
Any other ideas?
To see my system set up you can click on the specs tab and look at the parts to the right of the slash. The left is another system. But basically the above with a lot of fans and a very open case with high airflow. Also the 2080ti cards are turbo, and never go above about 55 degrees and blow the heat out the back of the case (which has industrial grade Noctua fans).
As for configuration, I have only set the memory and fans in the Bios. The memory settings are as per the memory timings, etc. and were the same with the previous two Bioses--and caused no problems. The fans are fine, and I monitor all of my temps with HWMonitor whenever my rig is on, and I eyeball everything regularly.
Also, thank you for your quick reply.Last edited by Super Gnome; 10-26-2020 at 01:29 PM.
10-26-2020 02:00 PM #4
- Join Date
- Jul 2014
- Reputation
- 11
- Posts
- 148
I'd rather look in other directions than RAM settings... RAM instability usually brings to BSOD, not to shutdowns.
Do you have more than one monitoring software? I remember at the very beginning of Zen2 platforms, using more than 1 monitoring software caused shudowns, in my rig there were iCue and AIDA, stopping using one of them solved the problem.
Can't think of anything else at the moment, but I'm strongly convinced it's not a matter of RAM.
10-26-2020 06:51 PM #5
- Join Date
- Oct 2019
- Reputation
- 10
- Posts
- 3
Same Problem
Hi, i encoutering the same problems with ROG Crosshair VIII Hero after latest BIOS.
10-26-2020 10:29 PM #6
- Join Date
- Mar 2019
- Reputation
- 28
- Posts
- 394
Interesting. For about six months, with a Bios for a different Asus motherboard, I had the same, plus loads of BSODs. With the latest BIos for that board, the problems conclusively stopped. Also note, that with one Bios, at least a few users had extremely high, stuck CPU clock speeds and very high CPU temperatures, and as a result we all had to switch back to a previous Bios.
Regardless, let's see if anyone else reports the same. It is tempting to switch back to the most recent previous BIos, but let's see if we get more of these problems and if others report the same.
I use HWMonitor only.
Thanks for the replies guys.Last edited by Super Gnome; 10-26-2020 at 10:55 PM.
10-26-2020 11:42 PM #7
- Join Date
- Mar 2019
- Reputation
- 28
- Posts
- 394
Just got a BSOD (a day after the above), the first one for this computer. The system ran perfectly otherwise since built, now about six months ago. At the time of this BSOD, I had literally nothing running but NZXT Cam. It was precisely upon hitting "Shutdown" on the Windows menu, and whether or not this is by chance is unknown.
10-27-2020 10:04 AM #8
- Join Date
- Jul 2019
- Reputation
- 10
- Posts
- 3
This morning this happened to me for the first time ever on my system.
I was surfing this forun and PC has suddenly shut down and after a few seconds, started again itself.
Only monitoring software is NZXT Cam.
My PC specs. are:
Crosshair VIII Formula - Last Bios2311
Ryzen 7 3800X
2x8 GB Ram GSkill Neo 3600 Mhz. 16-16-16-36
Main Drive Samsung 980 Pro 1TB NVME Gen4
Secondary HDD Seagate Barracuda 8TB
GPU ASUS TUF Geforce RTX 3080 OC
PSU Asus ROG Thor 850 WLast edited by Javi7269; 10-29-2020 at 06:31 AM.
10-27-2020 12:43 PM #9
- Join Date
- Sep 2020
- Reputation
- 10
- Posts
- 42
Any of you that have shutdown issues apply voltage tweak cos x570-e also got new bios it seems to apply a voltage tweak by it self its using far less voltage runs far cooler and clocks much higher with new records in cinebench, so voltage tweak you had before may not be stable anymore
