Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    Oct 2020
    6
    Question Issue with RAMPAGE VI EXTREME / i9-7980XE / GTX 1060 / CMK32GX4M2Z2400C16
    Hello Everyone,
    I'm writing this post because I'm struggling to understand why my PC is getting an annoying issue that seems to come back over and over.
    The configuration is the following:
    ROG RAMPAGE VI EXTREME Rev 1.xx Bios 3105
    Intel Core i9 7980XE
    128 GB Corsair CMK32GX4M2Z2400C16
    NVIDIA GeForce GTX 1060 6GB (GP 106-400)
    Samsung SSD NVMe m2 850 pro
    Windows 10 pro 1809
    The Bios is set all in auto so no overclocking in place.
    I tried to update to the latest bios available to see if the issue was fixed but I'm still have it.
    Basically what is happening is that the PC remain in a sort of frozen status, no output in the video, not connected to the lan (no ping),you can press mouse and keyboard without have any effect, i also checked the windows logs and i can't find anything helpful to understand the issue.
    All the drivers have been updated, i stress tested, CPU, Ram, Video card, full stress test , and no one showed any sort of issue.
    Temperatures are fine, CPU got the water block on it, and also the mini display on the mainbord seems working normal showing temperatures and no erros.
    It can happen when is in idle , or when no one is logged, happened also when it was on a render manager (Deadline10) and rendering in maya or nuke. The only thing that you can do is manually reboot it.
    I tried to check bios settings as well following some advices from the forum here but the issue is still happening, it was happening with the old bios (2/3 version before) as well.
    Does anyone have some advices on how to fix this issue?
    Any help will be really appreciated.
    Cheers in advance.
    Pirus
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,689
    ROG Guru: Green Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME BIOS 3501 MOD
    ProcessorIntel Core i9 7980XE 2.60GHz
    Memory (part number)64GB GSKILL 3.2 GHz 16-16-18-36 2T
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG ODESSEY G9 NEO 49 Firmware 1005.1
    Storage #1SAMSUNG 970 EVO PLUS 1TB x 3
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 11 Insider Preview 22509.1011
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    104
    745
    How long had been your setting up purchase ? If not over 30 days on refund time I'd like to recommend you to exchange CORSAIR kits to GSKILL DRAM.
    3 years ago I use GSkill 64GB DDR4 3200 kit with XMP Profile working with no any issued since Windows 7 to Windows 10 2021 H2 Insider Preview Build 20241.1005.
    Windows 11 22H2 Build 22509.1011 Core i9 7980XE 02006COA MCU 2021-06-16 R6E 3501 MODDED BIOS TPM 2.0 Enabled VROC 7.6.0.1023 + RST 18.31.1.5256 ME FW 11.12.90.1962 DV 2131.1.4.0 64GB DDR4 3200 XMP POSEIDON 1080i GTX NVIDIA Driver 510.31 WHQL 3TB SAMSUNG 970 EVO PLUS OMS Driver 18.36.4.1022 WHQL i219 V OROM 0.1.00 BA 0.1.16 12.19.1.37 WHQL AQC 107N FW 3.1.121 AQC 3.1.4.0 WHQL Realtek HD 6.0.9268.1 WHQL SAMSUNG ODYSSEY G9 49 NEO FW 1008.1 VESA HDR 2000 DP
    ROG Guru: Yellow Belt Array
    Feb 2019
    20
    153
    Quote Originally Posted by IAMPIRUS View Post
    Hello Everyone,
    Windows 10 pro 1809
    Cheers in advance.
    Pirus
    Sounds very similar to a problem I and others have had with the R6E board. In our case, it was related to that the right side memory banks are unstable and
    solution was to ONLY populate the left side memory slots.
    Try it and see if that helps.
    Read more about that here: https://rog.asus.com/forum/showthrea...g-XMP-settings
    ROG Member Array
    Oct 2020
    6
    Thanks you for the help, unfortunately, the PC is couple of year old and have been given to me only now.
    i got the 2nd pc with same components but with the ROG STRIX X299-XE as MB and it seems fine, no issue at all.
    Do you advice o get a 4x32 certify vendor and use it on the left series or ram banks?
    i will have a go to the bios setting properly and check them.
    Really apprecitated the help.
    ROG Member Array
    Oct 2020
    6
    I tried to check the bios but I couldn't find the XMP settings.
    Pretty sure those kits support XMP 2.0.
    It can be linked to the fact that all the slots have been filled and 4 kits 2x16 have been installed?
    Do you have any suggestion on how to set up the bios to have more stability?
    The 128GB kit by corsair CMK128GX4M8A2400C14 is discontinued.
    thanks in advance.
  7. #7
    ROG Guru: Orange Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    13
    304
    Gskill has a number of 64 & 128 gb kits available for x299.
    DON'T MIX OR COMBINE KITS
  8. #8
    ROG Member Array
    Oct 2020
    6
    Quote Originally Posted by G75rog View Post
    I tried to scan the ram with RAMMon as well and the kits seems all having same chipset and hw specs.
    Do you have a model number of a 128 GSkill kit still on sale that is compatible or in the Qualified Vendors List (QVL) for the X299.
    on the latest update of the vendor list, i can't see any 4 x 32 compatible kit.
    Cheers
  9. #9
    G75rog PC Specs
    ProcessorI9-7900X
    Sound CardStock
    Jan 2013
    13
    304
    Newegg has a variety of Gskill x299 kits to sift through.
    I'm not a shopping nanny, just pointing out a usable source.
  10. #10
    ROG Member Array
    Oct 2020
    6
    Thanks for the hint. many kits in that vendor list are discontinued, this is why I was asking if anyone knew one that was still in sale.
    Found a gskill one only and is 1500£ as discontinued product.
    will carry on to search as asus assistance replied me that no 32gbx4 are in the vendor compatibily list.
