Results 1 to 5 of 5
    ROG Member Array
    Jul 2013
    16
    Strix 3090 LED won't turn on?
    Really weird issue... So when I first installed the 3090 the LED's on the card worked fine and synced with Armoury Crate just fine. However, after turning off the computer during the night when I turned it on this morning I noticed the LED's on the card were completely off during boot up and when windows was up and running. I launched armoury crate and it detects the card, but changing the lightning effects has no effect on the graphics card.
    My last resort was I turned off the computer and manually switched the PSU to off and waited about a minute. After doing so, I turned on the computer and voila LED's on the graphic's card is on and running just fine. Turned the computer off while I went to work and just turned it on after an 8 hour day and the same thing is happening again!!!
    New ROGer Array
    Aug 2020
    8
    stealth button on GPU
    there should be a stealth button on the GPU did you try to press that to see if it works then.
    New ROGer Array
    Oct 2020
    1
    I'm having the same issue. From what I can tell, it's GPU Tweak II that is conflicting with Aura Sync.
    Rgb's work fine when I star up my computer, then GPU Tweak kicks in whenever I change the modes and it corrupts the rgb on the 3090 which starts flashing random colors then just straight shuts off until I restart my computer.
    We need a fix for this asap, especially considering how much I paid for this 3090
    Administrator Array MasterC@ROG's Avatar
    Aug 2014
    117
    1,706
    We will look into this. Armoury Crate V3.2.4.0 will be released in less than 3 hours. Please try again then. Uninstall the current version of Armoury Crate first, reboot, and install the new update.
    ROG Member Array
    Jul 2013
    16
    Haven't tried the new Armoury Crate just yet, but the solution/workaround was for me to go into my mobo bios (maximus XII extreme) and enable (s4+s5) and disabling onboard LED when computer is off. After doing this every time I fire my computer on the LED's on the STRIX 3090 work perfectly fine.
