Will All in One 360mm Cooler be enough for i9 10850 with 3080 VGA card
Shutt
Hi
Wanting to buy a cooler though got to 2 I liked being EK 360MM and Asus strix ROG 360MM
though now worried it may be not enough, though will have 6 x120 case fans. Would only overclock to 5Mhz
Sure others would have had the same concern.
Thanks in advance
Arne_Saknussemm
Level 40
That should be OK. It really depends on you finding the maximum airflow through your case.
Good fans on an AIO are a must but both your choices come with good fans so...
Just balance intake and exhaust properly and make sure your case fans can move air
Thanks for your reply, I bought the Ek AIO and looking now to use on top of Lian Li 011 Dynamick xl case as exhaust and 1 at the rear. I was going to use 2 fans at the bottom and 3 at the side as intake.
Not sure if this will work though if not can change around.
