Results 31 to 40 of 203
11-22-2020 12:16 AM #31
MrHDR PC Specs Motherboard Rog Maximus X Hero Processor i7-8700K Memory (part number) G.Skill Trident Z RGB 3200MHz CL16 32GB Graphics Card #1 Asus GeForce RTX 3090 Strix OC Monitor Acer XB271HU Storage #1 Samsung 970 Evo 500GB M.2 | WD Black SN750 1TB M.2 Storage #2 2x Firecuda 2TB CPU Cooler EK-AIO 360MM Case Fractal Design S2 Gunmetal Power Supply Corsair RM850x Keyboard Razer Huntsman Elite Mouse Razer Viper Headset Astro A40 OS Windows 10 Pro
- Join Date
- Dec 2016
- Reputation
- 10
- Posts
- 9
Also having this issue unfortunately, it's kind of a shame considering the card is priced at 2310 USD here.
11-22-2020 02:33 PM #32
- Join Date
- Oct 2017
- Reputation
- 10
- Posts
- 35
Interestingly the rattling sound that my graphicscard "had" came back when testing simple overclock with fans at 100%. So could the rattling be somehow heat related, the sound went away when I turned the fans down not when I quit the test program. On positive note my first whining fan seems to have gotten quieter, but still there seems to be the varying sound output while the middle fan whining sound is constant. So in the end now I have somewhat pulsing higher pitched whine, with rattling that varies a bit.
11-23-2020 03:06 PM #33
- Join Date
- Feb 2012
- Reputation
- 10
- Posts
- 8
I have been lucky to acquire a second 3090 Strix OC via Amazon which was delivered to me today quite out of the blue after ordering already on the 20th of sept.
This new one is absolutely quiet (except for some coilwhine) and seems to cool better as well. It's proof that the ones that have this issue are definetely faulty. I've returned the first one to the store. Good luck to everyone and game on!
11-24-2020 08:47 AM #34
- Join Date
- Feb 2019
- Reputation
- 15
- Posts
- 920
Dear all,
I would like to update the information I need to collect,
this request is for only ROG series, 3070,3080,and 3090 owner
I would need to collect below information.
If you have already send me PM, no need to do it again.
1. Full name
2. Product SN
3. Country/Region you stay
11-24-2020 02:39 PM #35
- Join Date
- Nov 2020
- Reputation
- 10
- Posts
- 29
Is there any update as to what is causing this? It's rather annoying now. I heard on the grape vine that the ones that are not buzzing cool better (as JustinN noticed) maybe the shroud is not fully clamped down enough against the PCB/DIE?
11-28-2020 03:06 AM #36
- Join Date
- Oct 2020
- Reputation
- 10
- Posts
- 8
11-30-2020 10:37 AM #37
- Join Date
- Sep 2015
- Reputation
- 10
- Posts
- 38
I had this issue with my 3090 ROG Strix but adjusting my gpu sag bracket seems to have cured it... took a few attempts to get it right. Ran furmark to test fans from 1000 (i have the issue where they run at 1000 even at idle) to 1850 RPM and it was fine all the way through
11-30-2020 11:16 AM #38
- Join Date
- Nov 2020
- Reputation
- 10
- Posts
- 29
11-30-2020 11:19 AM #39
- Join Date
- Nov 2020
- Reputation
- 10
- Posts
- 29
I have a support holding up one end, mine simply just changes when it occurs, although you can remove the issue by holding it (as you found it), its just being masked, the issue is still present, something is not right. Ive undervolted and adjusted fans so i don't hear it until ASUS come up with a solution, which we are still waiting on.
11-30-2020 11:23 AM #40
- Join Date
- Sep 2015
- Reputation
- 10
- Posts
- 38
