can anyone please help me with this - bios issue
Undertoker
hi guys
i am running a H370-F Gaming asus strix motherboard
Try as i like i cannot get into the damn bios, ive tried doing it from windows using the uefi setting it just goes straight into windows
Ive tried spamming the delete key and also the F2 key and ive also tried a different keyboard
I cann get into the bios - it is really pissign me off in honesty
does anyoen have any suggestions please ?
The pc is otherwise running ok, but i want to getinto the bios and it is doing my head in not being able to even see it
The text doesnt even scroll past to see the chance to do it.
The pc was a pre build from overclockers and is one of the rare PC's i bought ready built as i was jsut too busy to build one
can anyone help me or suggest what i can do please
I9 14900K >ASUS ROG Strix RTX 4090 OC Edition
ASUS ROG MAXIMUS Z690 EXTREME EATX Motherboard
ASUS ROG PG35VQ @ 200mhz in 3440x1440
Trident Z RGB 64GB DDR5 @ 6400mhz
Samsung 980 EVO Pro M.2 x 5 off
NZXT Z63 Kraken AIO CPU Cooler
NZXT H700i + Hue 2 (Pubg Edition) - Heavily modified
ASUS ROG THOR 1200w PSU
Corsair M65 RGB Mouse
Corsair K95 RGB Keyboard
Braegnok
Level 14
For entering BIOS setup at startup, press or during the power-on self test (POST)
Three ways for entering BIOS setup after POST:
1. Press ++ simultaneously.
2. Press the reset button on the system chassis.
3. Press the power button to turn the system off than back on. Do this option only if you failed to enter BIOS Setup using the first two options.
After doing either of the three options, press key to enter BIOS.
Good Luck
no1yak
Undertoker wrote:
hi guys
Do you have windows fast start up enabled ? if so then disable it and try to enter the bios.
