Results 1 to 3 of 3
    ROG Member Array
    Feb 2013
    24
    Exclamation Asus System Analysis for MYASUS crashes daily over 200 times
    Asus System Analysis, the software that MYASUS app uses to identify the hardware, crashes over 200 times each day. I get tons of error messages in the Reliability Monitor, repeating each 5 min.
    The file causing problems is located in this folder:
    C:\Windows\System32\DriverStore\FileRepository\asu ssci2.inf_amd64_34ba03d292044348\ASUSSystemAnalysi s\ [AsusSystemAnalysis.exe]
    It mentions this module that is faulty: AsusWinIo64.dll.
    I am using the latest version of all the software.
    Thank you! I am looking forward for a fix.
    New ROGer Array
    Jul 2020
    18
    106
    Quote Originally Posted by KITT 2013 View Post
    Follow this:
    Enter control panel and go into add and remove programs
    in the search bar type "Asus"
    Uninstall "My Asus"
    Goto C:\Windows\System32\DriverStore\FileRepository\
    Search for asussci folders
    Ensure that they are deleted or that the contents are deleted.
    goto https://www.asus.com/support/MyASUS-deeplink/
    Download My Asus
    Restart
    visit the same webpage and accept the popup prompt to open my Asus.
    Its likely that the .dll you mentioned is corrupt and will require a clean install
    ROG Member Array
    Feb 2013
    24
    Asus launched a new update for MYASUS app and I have noticed that after the update the crashes didn't happen anymore. Although imma still check for it and if I see anymore crash related to the system analysis I will do what you told me. Thank you!
Tags for this Thread
