Results 1 to 4 of 4
    ROG Member Array
    Mar 2012
    21
    GPU Tweak Monitor causing framerate drops
    Well one re-install and one restore of Windows later I can report that GPU Tweak's Monitoring overlay (both Widget and Standard) is causing severe frame rate drops each time it updates.
    After noticing gameplay smoothness feeling horrible, I tested using Heaven benchmark, BF3 and Project CARS - all of which were showing similar signs.
    TLR - if you have GPU Tweak's Monitor anything other than closed, you will be hit with a frame rate drop each time it updates.
    For those of you that love graphs - here is a frametime graph for a 10second period. (from top to bottom) Monitoring off, Monitoring on (1sec interval), Monitoring on (3sec interval)
    ROG Enthusiast Array el terrible PC Specs
    MotherboardASUS Maximus X Hero
    Processori7-8700K
    Memory (part number)G.Skill Trident Z 3200mhz cl14 RGB
    Graphics Card #1ASUS GTX 1080 Ti Poseidon
    MonitorBenQ XL2546 1080p 240hz
    Storage #1Samsung 960 EVO 1TB
    CPU CoolerEKWB Supremacy EVO
    CaseFractal Design Define 7 TG
    Power SupplyCorsair HX850 Platinum
    Keyboard Steelseries Apex Pro TKL
    Mouse Steelseries Rival 310
    Headset Logitech G-Pro
    Mouse Pad Steelseries QcK Heavy
    OS Windows 10 Home
    Jul 2011
    12
    44
    oh really? I have been getting random spikes every now and then when i'm gaming but I never figured out what was causing it... i never suspected the gpu tweak monitor beeing the problem.. guess i'll try to disable it for a few days and see what happens.
    Disabling the monitor doesn't have anything to say safety wise, right? I use Real Temp watching my GPU temperature anyways and I have the fan settings on User Define.. it will still change every time it hits certain temps even though I have the Monitor program disabled, right?
    ROG Member Array
    Mar 2012
    21
    The program seems to operate as normal if you close the monitoring tab and leave the GPU Tweak app open. Alternatively, just install MSI Afterburner and you can see the same things, with none of the frame rate losses.
    Processori7-8700K
    OS Windows 10 Home
    Jul 2011
    12
    44
    but you can't tweak the Matrix Platinum gtx 580 with afterburner... I really wanted to use afterburner but I can't tweak fan controls or anything, so my card gets way too hot... If afterburner was a option I would change a long time ago from this bad beta program....
