Results 1 to 5 of 5
    New ROGer Array
    Aug 2019
    9
    SRIX G512LV 144Hz display looks washed out. Any way to fix it?
    The laptop's display looks really washed out. I assume it's because full RGB is not enabled because my external display looks the same when I enable limited RGB. My previous FX505DT had a similar quality display but the colors looked much much better than this one. I also can't find an option to enable full RGB in Intel Command Center. Any way to solve this?
    New ROGer Array
    Jul 2020
    18
    106
    Quote Originally Posted by Hisuiiki View Post
    Press the rog button/bring up armoury crate
    go to the 5th option from the side list that is game visual
    select a screen preset
    better viewing experience
    New ROGer Array
    Aug 2019
    9
    No, I'm sorry. All of those make it worse on the Desktop and most of them are really bad.
    New ROGer Array
    Aug 2020
    21
    30
    I found on my G732LWS I have to Open the Intel Graphics Center and goto the color tab and and hit the button for "Restore Original Colors"
    this maybe because it seems Asus has loaded a Color Management Profile which must be generic and not valid for my particular Panel.
    You can check in Control Panel> Color Management and see it maybe you have the same issue.
    KB
    Moderator Array
    Feb 2019
    13
    561
    Hello Hisuiiki,
    May I have a picture of the issue ?
