Results 1 to 3 of 3
Thread: PWM issues
    ROG Member Array
    Jan 2018
    9
    PWM issues
    Hey all,
    I'm trying to wrap my head around as to what I'm doing wrong here.
    I've upgraded my 4 PWM Corsair fans recently to the Corsair LL series.
    They're connected to the node pro hub for the led/light effects and from there their 4 pwm pins go to the same splitter that ends up in the CPU_FAN of my VII Maximus Ranger mobo.
    Everything works as it should, lights effects etc but I have absolutely no control.
    AI Suite 3 shows a PWM max fan speed of 750-800RPM.
    Help?
    ROG Guru: Yellow Belt Array Baio73 PC Specs
    Baio73 PC Specs
    MotherboardAsus ROG Crosshair VIII Formula BIOS 3402
    ProcessorAMD Ryzen 3900XT
    Memory (part number)2x8 Corsair 4000C19D
    Graphics Card #1Sapphire RX 5700XT
    MonitorLG 34GK950F
    Storage #1Samsung 980PRO 512Gb NVMe
    Storage #2WD Black SN850 2Tb NVMe
    CPU CoolerCorsair H150i Elite Capellix
    CaseLian Li 011D XL
    Power SupplyCorsair AX860i
    Keyboard Logitech G513
    Mouse Logitech G903 + Powerplay
    Headset G933 Artemis Spectrum
    Mouse Pad Corsair MM 700 RGB
    Headset/Speakers Logitech G560
    OS Windows 10 64bit
    Network RouterLynksys EA6500
    Accessory #1 Corsair Commander Pro
    Accessory #2 10xCorsair QL120 RGB fan
    Jul 2014
    11
    154
    Quote Originally Posted by stocis View Post
    Hey all,
    Help?
    I can’t understand where you connected the 4 fans PWM cables... what is “the same splitter”?
    Anyway, if you are planning to control your fans speed via BIOS (or AI Suite), try to connect them to mobo headers, directly if you have 4 available, or via Y splitters.
    Â*
    BaioÂ*
    CASE Lian Li 011D XL CPU AMD Ryzen 3900XT COOLER Corsair H150i Elite Capellix MOBO Asus ROG Crosshair VIII Formula RAM 2x8 Corsair 4000C19D PSU Corsair AX860i VGA Sapphire RX 5700 XT DISPLAY LG 34GK950GF AUDIO Logitech G560 SDD Samsung 970PRO NVVe 512Gb - WD Black SN850 2Tb NVMe NPUT Logitech G903 + Powerplay + Corsair MM700 RGB - G513
    ROG Member Array
    Jan 2018
    9
    Quote Originally Posted by Baio73 View Post
    Â*
    BaioÂ*
    hi thanks for your reply
    I'm using this
    which was the splitter fan i was using before.
Tags for this Thread
