Results 1 to 5 of 5
    New ROGer Array
    May 2020
    2
    Aura Creator stopped working
    Hi guys,
    my Aura Creator stopped working with no reason (version 2.1.3).
    Afret loading my profile I click on "save and apply" and I get this error:
    Traslation is more or less: "Service Error. Restart the system and try again". Then if I click the OK button the AC app freezed.
    I tried restarting many times but I always get the same error.
    Thank for helping.
    ROG Member Array
    Jul 2020
    22
    Quote Originally Posted by porcodio View Post
    Hi guys,
    Thank for helping.
    Try updates from Microsoft store and then services from Armoury Crate and then reboot.
    New ROGer Array
    May 2020
    2
    Both armoury crate and aura creator are updated
    ROG Member Array MJr418 PC Specs
    MJr418 PC Specs
    MotherboardPrime x570-p
    ProcessorAMD Ryzen 5 3600
    Memory (part number)4 x 8gb Vengeance pro RGB
    Graphics Card #1MSI GTX 970
    MonitorDual LG 24"
    Storage #1Samsung 850 Evo
    Storage #2Samsung 860 Evo
    CPU CoolerCM 212 Hyper BE RGB
    Casenot branded case
    Power SupplyThermaltake Toughpower
    Keyboard Logitech G815
    Mouse Logitech G600
    Headset Logitech G pro
    Headset/Speakers Logitech Stereo Speakers
    OS Windows 10 pro
    Accessory #1 aRGB Fans
    Accessory #2 aRGB Strip
    Oct 2020
    18
    Have same problem, using the uninstaller then install still same thing, if I repeat and install aura creator it will work but it will break armoury crate, then after restart pc the same problem comes back armoury crate works but aura creator doesn't.
    Armoury Crate 3.2.4.0
    Aura Creator 2.1.3
    both worked kind of fine when armoury was 3.1.6.0
    New ROGer Array
    Oct 2016
    2
    Same problem
    Same problem for me on ROG G731GW, i've found a workaround which is working in my case:
    1. Kill lighting service process from Task Manager
    2. Open Aura Creator APP
    3. Setup or load lighting profile
    4. Run profile for > 1 minute
    5. Save and Apply
    Let me know if it's working for you also.
    I have also noticed since a couple of updates that in Armoury Crate APP in the Aura sync Advanced Effects dropdown menu my profiles are not listed.
    Has someone found the same problem?
    Armoury Crate UWP App 3.2.4.0
    ROG Live Service 1.1.10.0
    AURA Service (Lighting Service) 3.04.24
    Armoury Crate service 3.2.5
    ASUS AIOFan HAL 1.1.2
    ASUS AURA Motherboard HAL 1.0.61
    ASUS Aac_NBDT HAL 2.4.2.0
    AacVGA 0.0.2.6
