Results 1 to 3 of 3
11-12-2020 01:17 AM #1
- Join Date
- Jul 2020
- Reputation
- 10
- Posts
- 1
Android TV 9 won't connect to Wi-Fi 5Ghz ac
I have 2 Asus Routers connected to each other using an Ethernet Cable in a iMesh configuration:
- 1 GT-AC5300 firmware 3.0.0.4.384_82037-g0cfb8f0 as master node
- 1 RT-AC1750_B1 firmware 3.0.0.4.386_40558-gc48f410 as a AiMesh node
I've set them up to use Wireless Smart Connect.
I have one TV running Android TV which can't not connect to the wifi network when it is near the node. It was able to connect to the master node. I tried to find in the interface where to change the channel configuration to see if that solves the problem but the only option I can select is AUTO.
What can I do to fix the problem?
Thanks
Gilson
11-16-2020 08:21 AM #2
- Join Date
- Apr 2020
- Reputation
- 10
- Posts
- 35
11-20-2020 03:07 PM #3
