Asus Helios case fans issue!
omxiip
Hi all,
I have asus strix helios case which comes with 4 fans, is there any way to control the fans by using a software?
It is only controllable by the button on the top of the case!
thanks
skyhopper01
In the stock config, the only way is to control them via the Controller at the front. You could technically plug them into your motherboard, but you would need 4 DC headers. You could also plug them into the PWM fan headers on your motherboard, but this will force the fans to run at 100 percent. I am actually going to be replacing all of my case fans in the Helios to Noctua Industrial pwm fans for maximum control. In order to do this I will need a fan controller hub. Hope this helps.
Thanks for the info .. I got Corsair commander pro to control the fans.
