Results 1 to 1 of 1
    ROG Guru: Orange Belt Array R5Eandme PC Specs
    R5Eandme PC Specs
    MotherboardRampage V Extreme/U3.1
    Processori7-5930K
    Memory (part number)Corsair Vengeance LPX CMK64GX4M8A2400C14
    Graphics Card #1MSI Geforce GTX 980Ti
    Sound CardAsus Essence STX II
    MonitorAcer B286HK 4K UHD
    Storage #1Samsung 960 Pro 1TB NVMe
    Storage #2Samsung 850 Pro 1TB SSD
    CPU CoolerNoctua NH-D15S
    CaseCooler Master HAF 932
    Power SupplyThermaltake TPG-1200M-F 1200W
    Keyboard Corsair K70 Cherry MX Brown
    Mouse Asus Sica
    Mouse Pad "And God said ... <Maxwell's equations> ... and there was light."
    OS Win 10 x64 Pro
    Accessory #1 Asus USB 3.1 A, StarTech USB 3.1 C PCIe adapters
    Accessory #2 Syba 1394A/B Firewire PCIe adapter PEX30009
    Accessory #3 Asus OC Panel I
    R5Eandme's Avatar
    Jun 2017
    58
    274
    External USB 3.0 enclosures (UASP compatible) not recognized or connection unstable
    I have a couple of new external USB 3.0 enclosures (UGreen 30848 and StarTech S251SMU33EP) containing SSDs. Using the R5E with X99 chipset the connection to mobo USB 3.0 ports are unstable and keep disconnecting, if they are recognized at all. If I plug them instead into my add-on USB 3.1 (10 Gbps) ports on my PCIE cards, they connect stable and work fine. Any ideas?
    I wonder if it is because these external enclosures support UASP (USB Attached SCSI Protocol) for extra speed, and maybe the mobo USB 3.0 and drivers are too obsolete to play nice with UASP enclosures? In Device Manager under "Storage Controllers" they appear as "USB Attached SCSI (UAS) Mass Storage Device" when connected through the USB 3.1 PCIE cards.
