Results 1 to 5 of 5
11-26-2020 12:18 AM #1
Nomad1977 PC Specs Laptop (Model) Lenovo W500 Motherboard Asus Maximus IX Hero Processor i7-7700k Memory (part number) 2 x G Skill TridentZ RGB F4-4000C17-8GTZR Graphics Card #1 MSI GTX 1070 Gaming X 8G Sound Card Asus Essence STX II Monitor Apple Cinema Display 27" Storage #1 Samsung 970 Evo 500Gb Storage #2 WDC WD20EARX-00PASB0 CPU Cooler Asus Ryou 240 Case Thermaltake Core P3 Power Supply Corsair RM850i Keyboard Asus ROG Claymore Mouse Microsoft Bluetooth mobile mouse 3600 Headset Sennheiser PX 200 - II Mouse Pad Corsair MM300 Extended Headset/Speakers Asus ROG Centurion 7.1 OS Windows 11 x64 21H2 Network Router Zyxel Keenetic Giga III Accessory #1 NZXT Usb hub Accessory #2 Asus OC Panel II Accessory #3 Logitech Driving Force GT
- Join Date
- Oct 2018
- Reputation
- 17
- Posts
- 10
ROG Centurion 7.1 wire repair and tuning (no sound left ear)
Hello! So, I decided to write a mini-guide.
I have two headphones:
- Sennheiser - only for Hi-Fi music (FLAC), they work through the Asus Xonar Essence STX II;
- Asus Centurion 7.1 - for games only, because the quality of the DAC for stereo mode is slightly inferior to the Xonar, but 7.1. works well, there is a microphone and the docking station is quite convenient.
There are only three complaints about the build quality of the Centurion 7.1:
- the sleeve on which the cup rotates breaks;
- overheating of the sound chip;
- sound failure in the left cup.
Accordingly, the bushing can be repaired by making a new one using 3D printing or by screwing the cup tightly with screws.
Overheating of the sound chip is solved by disassembling the station and gluing a suitable radiator on it. Because there is not enough space, then to exclude a possible short circuit, you need to bite off the protruding contacts on the top board a little.
The failure of the sound in the left cup is the reason for the breakage of one of the wires at the place of the wire termination in the safety sleeve, presumably by too strong a robot force on the machine. In this guide, we will talk about replacing the wire, tk. ironing for the second time about $ 200 for new headphones seems unreasonable to me, if you have a soldering iron and your hands grow from where you need to, ahah)) In general, the store bought the thinnest and most flexible HDMI cable, three types of heat shrink tubes for different diameters, and aliexpress a new sheath has been ordered. First, all the wires were sealed off one by one and the tester rang out all the wires to restore the connection diagram, then the safety sleeve was cut along and its inner diameter was modified with a file for a new cord (it turned out to be 1.5 times larger in diameter).
Soldering new wires, I recommend starting with the manufacture of a splitter from wire #20, because comes from the connector one, and is soldered to 4 points.
Then wire 12, soldering everything on this line, then wire 18, soldering all the points of this line, and finally from wire 20 in the microphone connection line.
Enjoy! ))Last edited by Nomad1977; 11-26-2020 at 12:24 AM. Reason: text error
01-14-2021 04:32 PM #2
- Join Date
- Nov 2014
- Reputation
- 10
- Posts
- 1
Thank you!
Hi, thank you for taking the time to write this and adding the pictures.
I just saved my Centurions with the same issue thanks to you.
I re-used the original wire and re-soldered all strands by colour to make it easier for myself, just lost 10cm of length, but not an issue with my setup.
A dab of superglue and a few heatshrinks on the cup sleeve to hold it in place and it worked a treat.
I already did a similar job once, when extending the joystick-throttle wire for my T-Flight Hotas, so I knew how difficult an HDMI can be.
However, I am especially grateful for the heatsink solution for the base unit!
I fiddled around with the software and drivers for weeks, scratching my head why it kept resetting, seemingly at random.
I just slapped one on, and will test it out shortly.
04-27-2021 06:54 PM #3
- Join Date
- Apr 2021
- Reputation
- 10
- Posts
- 1
first and foremost thanks for the detailed pictures and advice Nomad1977.does anyone have a high res image of the original points where the colour cable goes.stupidly desoldered wires to fix but forgot to take photo
,mainly the wires that come from the other earpiece
thanksLast edited by brobro; 04-29-2021 at 06:31 PM. Reason: made clearer
07-08-2021 09:54 AM #4
Eguun PC Specs Motherboard Asus ROG MAXIMUS XI EXTREME (Z390 EATX) Processor Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz Memory (part number) Corsair DOMINATOR® PLATINUM 16GB (2 x 8GB) DDR4 4000MHz (SKU: CMD16GX4M2E4000C19 ver 4.31) Graphics Card #1 MSI - NVIDIA GeForce RTX 2080 8 GB GAMING X TRIO Storage #1 Samsung SSD 970 PRO 512GB Storage #2 Samsung SSD 960 PRO 512GB CPU Cooler Noctua NH-D15 Case Cooler Master MasterCase H500M Power Supply SeaSonic - PRIME Ultra Titanium 650 W 80+ Titanium Mouse SteelSeries Rival 500 Headset ROG Centurion true 7.1 OS Windows 10 Pro 64bits
- Join Date
- Feb 2018
- Reputation
- 10
- Posts
- 12
Congratulations and thank you for taking the time.
Idem to what you experienced: my plastic piece whose function is to hold & rotate the right cup broke.
I guess when fixing it I wasn't careful because my mic isn't working any longer.
I bumped into your material when googling a wire diagram before opening & testing.
Thanks for the effort, very useful material!
12-18-2021 12:52 AM #5
Gu@|iro PC Specs Motherboard ROG MAXIMUS IX FORMULA Processor Intel Core I7 7700k Memory (part number) F4-3200C16D-16GVKB x 2 Graphics Card #1 ASUS ROG Strix GeForce® GTX 1080 OC Monitor Alienware OptX AW2310 - 3D Storage #1 Samsung Ssd Evo 960 Nvme M2 Storage #2 Digital Hyperx Fury 120gb Ssd Raid 0 CPU Cooler Cooler Master MASTERAIR MAKER 8 Case Nzxt Noctis 450 Rog Edition Power Supply Nzxt 850w Hale90 V2 Keyboard ROG Claymore Mouse ROG Pugio Headset ROG Centurion Mouse Pad Mouse Pad Gamer Corsair Extended Xl Mm300 OS Windows 10
- Join Date
- Sep 2017
- Reputation
- 10
- Posts
- 4
hola como estas ....tengo un problema con el cable... me podrÃ*as ayudar y recomendar que cable hdmi comprar ya que me quedo corto !! saludos desde Argentina y gracias .!
