11-27-2020 11:32 AM - last edited on 03-05-2024 01:56 AM by ROGBot
12-28-2020 01:26 AM
05-01-2023 05:27 PM
I have same board and had the same issue... first I was using a Gen3 riser cable, I swapped it for Gen4... then set slot 3 from auto to 16X .. I removed the left side m.2 DIMM to free up all the lanes for slot 3. Then I got 16x on both 1 and 3. It would NOT work with the Gen3 riser" . I then installed an NVLINK bridge and enabled SLI in the Nvidia Control Panel. I have yet to get NVLINK to enable the links. "Nvidia-smi nvlink -s" says links are not enabled. Me thinks the M/B is broke. Fixed one issue only to have another one !!! thanks ASUS.
