Results 1 to 2 of 2
    ROG Guru: White Belt Array
    Dec 2011
    11
    100
    DIMM.2 Slot M.2 Drive Identification
    When I built this machine I made a note of what M.2 Drives were installed on the DIMM.2 Card (i.e. Left side was Apps & Right Side was for Games). I've since lost the paper I wrote it on and wanted to replace my Games M.2 drive with a larger capacity one (thanks Call of Duty). Is there any way to identify which drive is which on the Card (i.e. D:\\ & G:\\) without physically removing the drives with trial and error? Both drives are identical Samsung 970 Pro's.
    ROG Guru: Orange Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    13
    303
    You could get the Asus Hyper X 16 V2 card and just add another drive or 4.
    I run 8 NVME on my Apex for 13TB on board and zero Sata drives.
