ASUS Hyper M.2 X16 PCIe 4.0 X4 on a Zenith II Extreme Alpha
Swiso
Hello,
Could be possible to use this card to add 4 more M.2 drives in this MB, but using them as 4 separate drives and not in RAID ?
Thanks
5 REPLIES 5
Arne_Saknussemm
Level 40
Yes that works....just select PCIe raid mode for the x16 slot you mount the card in....it says raid mode but they will work as 4 separate drives....
With the obvious caveat that it depends on other lane occupation etc.
Hi Arne, thank you for the help.
[QUOTE=Arne Saknussemm;821209
What you mean ?
Supposing I will put the GPU in the PCIEX16_3 slot (should work at 16x), this Hyper card in the PCIEX16_1 (also 16x) and this card (https://www.sonnettech.com/product/allegro-pro-usb31-pcie.html)
in the PCIEX16_2 (8x), do you think it will work ?
Arne_Saknussemm
Level 40
Swiso
Thank you very much Arne !
Swiso
On the QVL list for this card, both the Sabrent Rocket 4 and Rocket 4 plus are not listed...
I know people use without any problem the Rocket 4...any reason why the Rocket 4 plus shouldn't work ?
Do you think It will be safe to assume it will work ?
Thanks for any input..
