Results 1 to 6 of 6
    New ROGer Array RollaDice PC Specs
    RollaDice PC Specs
    MotherboardAsus Maximus Code XI
    Processori7 8700k
    Memory (part number)Vengeance LPX 32gb 3200mhz CMK16GX4M2B3200C16
    Graphics Card #1ASUS ROG Strix GeForce STRIX GTX1080 A8G
    MonitorAcer Predator XB271HUbmiprz 27 Inch
    Storage #1970 Pro
    Storage #2970 Evo Plus
    CPU CoolerCorsair H100i V2
    CaseNZXT H440
    Power SupplyEVGA SuperNOVA 750 Watt P2
    Keyboard HyperX Elite 2
    Mouse Razer Lancehead Tournament Edition
    Headset Corsair VOID Pro
    Mouse Pad Roccat Taito
    OS Windows 10 Home
    Nov 2019
    3
    Maximus Code XII
    Hi all, just a quick question
    I currently use ROG Maximus Code XI motherboard.
    i'm looking to upgrade to a z490 but wanted to stay with the Code series, thing is the Code XII z490 doesnt seem to be available. Is there a reason why the code series wasn't continued on the z490? Also, if it's not available, what ROG motherboard series would you recommend that would be similer to the Code. i was looking at purchasing the ROG Formula z490 but wasn't interested in water cooling. Just want the same features as the code but Z490
    apprecaited.
    Nate152 PC Specs
    Memory (part number)16GB G.Skill Trident Z - 3600MHz 15-15-15-30-1T
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPCP&C Turbo Cool 1200w
    Keyboard ROG Falchion NX
    Mouse ROG Spatha X
    Headset ROG Delta S Animate
    Mouse Pad Steelseries Prism XL + ROG Scabbard II
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    312
    16,787
    Hello RollaDice
    Asus did away with Code in the Maximus XII Series.
    The Maximus XII Formula has the EK crosschill block which can be used for air or water cooling, the other choices would be the Maximus XII Hero WiFi or Maximus XII Apex.
    RollaDice PC Specs
    Processori7 8700k
    Storage #1970 Pro
    CaseNZXT H440
    OS Windows 10 Home
    Nov 2019
    3
    Quote Originally Posted by Nate152 View Post
    Hello RollaDice
    Hi Nate,
    Thanks for reply, yes im aware of the Hero & Apex.
    I think the issue for me is finding the closest board to the Code in regards to features. I'm currently looking at board comaprsions.
    when it comes to PCIe I'm not the most knowledgeable, so need some guidance if poss.
    on the Formula Z490 XII is says 2 x PCIe 3.0 x16 (x16 or dual x8)
    on my code Z390 XI it has 2 x PCIe 3.0 x16 (x16, x8/x8, or x8/x4+x4)
    im not sure what the difference is between the 2 readings with the formular having the extra x8/x8, or x8/x4+x4) info
    Would i be going backwards in any board features if i was to go for the Formular XII upgrading from the code XI apart from the chipset being an upgrade.
    Thanks again
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse ROG Spatha X
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    312
    16,787
    What it's referring to is the pcie lanes on the cpu which has 16 lanes + 8 lanes from the chipset for a total of 24 pcie lanes. This means you can use two M.2 ssd's without sacrificing cpu pcie lanes.
    The configurations are showing:
    x16 = 1 GPU
    x8/x8 = two nvidia gpu's or two amd gpu's
    x8/x4/x4 = three amd gpu's
    AMD gpu's need only x4 lanes to run where as Nvidia needs x8.
    You are not going backwards in any way.
    RollaDice PC Specs
    Processori7 8700k
    Storage #1970 Pro
    CaseNZXT H440
    OS Windows 10 Home
    Nov 2019
    3
    x16 = 1 GPU
    Perfect, thanks for explaining Nate.
    Nate152 PC Specs
    MonitorHP ZR30w
    Mouse ROG Spatha X
    OS Windows 11 Home
    Nate152's Avatar
    Feb 2013
    312
    16,787
    You're welcome
Tags for this Thread
