12-16-202008:07 AM - last edited on 03-06-202410:36 PM by ROGBot
My G20CB is in the fritz and there is a cheap G20AJ for sale. Can I swap the components (mobo, ram, GeForce 970, I7 6700 3.4 ghz, PSU) from the CB into the AJ case?
hello and welcome to forums, Only thing you can take from the CB to the AJ is the graphics card and the 2 power bricks, you will have to use the AJ's motherboard/cpu/memory. you can also take the hdd's over also.
The short answer is YES, apart from the RGB module and its connector all G20 models share the same chassis and power brick (only exception is G20CI which replace the onbaord HDMI with a usbc port so it has a different back io cover). You can use the AJ chassis for your G20CB components except the RGB lighting won't work unless you replace them.
