Results 1 to 3 of 3
    New ROGer Array
    Dec 2020
    2
    AI Suite Fan Xpert
    I have a problem with Fan Xpert in AI Suite.
    I have run calibrations for the fans and the reslut is that my fans can work between 40% (282 rpm) and 100% (884 rpm).
    But as you can see in the picture, the slowest I can chose is about 70%. Everything below is in the red area.
    See picture here:
    https://i.ibb.co/MgkDWDK/AISUITE.png
    What can I do?
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Steelseries Prime+
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,442
    Hi Juschi
    It's been a while since I've used this program and yours is in German, does clicking " RPM Fix-Modus " allow lower fan speeds?
    Cpu fan is showing 201rpm
    Cpu_Opt is showing 185rpm
    Chasis fan 1 is showing 605rpm
    Do the fans seem like they're running as above? Cpu temp looks good at 33c.
    New ROGer Array
    Dec 2020
    2
    nothing helped, so I edited the config file "FanCalibrationData.xml" under C:\ProgramData\ASUS\DIP\FanXpert
    and changed <maxdutytokeepstill> to a lower value.
    Now it works.
