GT-AC5300 WAN Speed Limited
eric4
So my Raptor GT-AC5300, which is supposed to have a 1Gig WAN port, seems to keep things capped at 90Mbps on a good day. I say good day, because it seems to vary between 40 and 90 Mbps.
I have turned off everything I could think of that may impact the speed; QoS, Firewall, AI Protection, turned off the mesh connect router, etc.
I have also manually set the speed limit to 20Mbps to ensure bandwidth limiting works and it capped it at 20 as expected. I have also manually set it to 1000Mbps, but still stops at 90.
I test both wired and wireless. I also know it's not my fiber switch, because when I plug in my laptop directly to the fiber which (on the same Cat6 as the router uses), I get my full 500 Mbps.
The only thing that I have not tried is to do a full factory reset.
Anyone else have/had this problem? Help!
0 REPLIES 0
