Results 1 to 9 of 9
    ROG Guru: Orange Belt Array Saltgrass PC Specs
    Saltgrass PC Specs
    MotherboardMaximus XIII Hero
    Processori9 11900K
    Graphics Card #1EVGA RTX 3090 FTW
    Sound CardOn Board
    MonitorDell AW3420DW
    Storage #1Samsung 980 Pro 2 TB
    Storage #2Samsung 860 Pro 1 TB
    CPU CoolerCooler Master Hyper 212X
    CaseCooler Master
    Power SupplyAntec HCP Platinum 1000
    Keyboard ASUS Strix Flare
    Mouse ASUS Chakram
    Headset/Speakers Logitech wired 5.1
    OS Win 10 Pro
    Network RouterROG Rapture GT-AX11000/AXE11000
    Accessory #1 VR Headset
    Accessory #2 Saitek X52
    Jan 2014
    18
    431
    Strix Flare XA01 doesn't seem compatible with Win 10
    I have just gone through a month of trying to find out why my new system would not upgrade to Win 10 20H2. I was also noticing my system would not sleep correctly and if it would sleep, if left there for a couple of hours, it would not wake in a normal mode but was completely unresponsive.
    Finally, after tracking down everything I could think of and multiple clean reinstalls, it seems the keyboard was the problem, even with the latest firmware. I finally replaced it with an old keyboard I have and was able to install Win 10 20H1 which easily upgraded to the latest 20H2 version. So the keyboard was keeping my system from doing normal Win 10 upgrades/updates..
    I don't know how a keyboard can cause such problems but I suspect the volume wheel was conflicting with something else. I was also using a Chakram gaming mouse which may have added to the problem. But replacing the mouse did not solve the problems but replacing the keyboard did.
    I won't be able to use the keyboard or mouse until a fix is released .. anyone know how I could best watch for that?
    Thanks for reading..
    ROG Guru: Yellow Belt Array fcsoares43's Avatar
    Aug 2018
    12
    142
    My problem is different i got a Asus Flare for two weeks now and the upgrade of windows was without issues maybe it was something else that wouldn´t let you system upgrade
    Regards
    ROG Enthusiast Array Razer68 PC Specs
    Razer68 PC Specs
    MotherboardASUS ROG STRIX Z390-F GAMING
    ProcessorIntel Core i7-8700K
    Memory (part number)HyperX Fury DDR4 3200MHz 16GB
    Graphics Card #1Nvidia GeForce GTX 1070 Armor OC
    Sound CardSupremeFX S1220A CODEC
    MonitorAsus 27" LED G-Sync ROG Swift PG278QR
    Storage #1Samsung 860 EVO 500GB SSD
    Storage #2Samsung 860 EVO 1TB SSD
    CPU CoolerCorsair Hydro Series H60 CPU Cooler
    CaseNoctua NF-F12 PWM 120mm Fan
    Power SupplyCorsair TX850M, 850W PSU
    Keyboard ASUS ROG Strix Flare Cherry MX/BUNGEER M4
    Mouse ASUS ROG Gladius II Origin / Xtrfy M42
    Headset ASUS ROG Throne/ASUS ROG Theta 7.1 Gaming Headset
    Mouse Pad ASUS ROG Sheath Mousepad/Xtrfy GP1 XL
    Headset/Speakers Edifier S530D
    OS Windows10 20H2
    Network RouterAsus ROG Rapture GT-AX11000 Nordic
    Accessory #1 ASUS RT-AC86U AiMesh AC2900
    Accessory #2 Fractal Design Define R6 Black
    Accessory #3 Asus Rog Strix Arion /Samsung SSD 2TB
    Razer68's Avatar
    Dec 2018
    41
    Thumbs up
    The problem is in the keyboards of the latest firmware.
    When I press any key on the keyboard, the computer does not wake up.
    Aug 2018
    12
    142
    Yes i Confirm that situation i tried it now and it occurs
    Razer68 PC Specs
    OS Windows10 20H2
    Razer68's Avatar
    Dec 2018
    41
    How do I solve this! In Armory Crate, check off the keyboards then there are no issue.
    We will have to wait for a new fix for this.
    Aug 2018
    12
    142
    Yes i have another problem i create a topic here i don´t know yet if is Hardware or software i hope this been resolve soon if you could see my post in this forum fgot a video an explain and tell me do you got same issue i would be appreciate Regards Thank You...
  7. #7
    Razer68 PC Specs
    OS Windows10 20H2
    Razer68's Avatar
    Dec 2018
    41
    Quote Originally Posted by fcsoares43 View Post
    Have you tried to do a factory reset on the keyboard?
  8. #8
    Aug 2018
    12
    142
    Quote Originally Posted by Razer68 View Post
    Yes three times reset but this happens someone tell me that all asus keyboard doing this... I thing soomething is wrong but i don´t know hat ... Thanks
  9. #9
    Saltgrass PC Specs
    Processori9 11900K
    Sound CardOn Board
    CaseCooler Master
    Mouse ASUS Chakram
    OS Win 10 Pro
    Jan 2014
    18
    431
    Strix Flare XA01 doesn't seem compatible with Win 10 - Resolved
    It looks like I need to remove the keyboard from the problem. After clean installing with the new mouse and old keyboard, I brought the install back slowly. The first time the wake from sleep incident started to happen was when I reinstalled my HTC Vive Cosmos Elite VR headset.
    It appears the VR Base Stations (movement tracking), unless unplugged, will cause my system to wake from sleep when I stand and move in their field of vision. I tested with the headset being unplugged from the wall and computer, so the base stations were all of the system left. Unplugging the Base stations does allow for the system to stay in sleep mode..
    The other problem regarding the system being unresponsive after waking from sleep may be tied to a recent Nvidia driver which I have not yet updated and that problem has not yet reoccurred. Video drivers are involved in a system's sleep capabilities..
