AURA CREATOR Why do i have to uninstall and reinstall every few day to make it work?
nitinvaid20
I have recently started using aura creator as there was no update for ASUS AURA it was really worth upgrading to ASUS AURA CREATOR but then the problem started
every day or in a two it shows "No device available" attached screenshot also
I have to uninstall and reinstall multiple times to make it work
I tried with Previous ASUS AURA then install AURA CREATOR
only AURA CREATOR
it works for once or twice then later when i check next day after reboot its not detecting why this is happening? its really frustrating
ASUS Z370F-Gaming Motherboard
Windows 10 pro
Araves
So be glad that you can do it at least for that one day ... I reinstall it about 10 times and still nothing.
