Results 1 to 6 of 6
    ROG Member Array
    Apr 2019
    22
    when will my system work normally?
    Hello
    i have a tuf Z390-plus gaming and a rog strix z490-g gaming (Wi-Fi) and all i get when switching sata mode selection is the message on the Screenshot.
    When will the systems work normally? Never?
    i m truly disappointed by asus that s the least to say,
    Regards,
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    329
    7,927
    *** Moved from SI section. Must have existing RMA ***
    Are you saying that when you change the setting it doesn't apply?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Orange Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.309SA )
    MotherboardAsus Builtin Motherboard X542UQ
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB DDR4
    Graphics Card #1intel HD 620 graphics 1GB DDR3 DCH WHQL driver v.30.100.9667
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5 DCH WHQL driver v30.0.14.7076
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec ALC294 WHQL driver v6.0.9151.1
    MonitorBuiltin Lcd monitor model BOE
    Storage #1Samsung 850 Evo 1000GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch 5400rpm and Seagate 2TB 2.5inch 5400rpm2.5 inch
    CPU CoolerBuilt-in
    CaseFrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Purchased Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek Builtin Speakers
    OS Windows 10 Enterprise 64bit v21H1 build no 19043.1055
    Network RouterNextVision ONU Fiber Modem
    Accessory #1 G40 Wired Gaming Mouse
    Accessory #2 Laptop Cooling table with fan
    Accessory #3 Secureye Usb finger print scanner added seperately for Windows Hello
    raju2529's Avatar
    Feb 2018
    9
    362
    Arnold , do bios reset , or adjust to default settings ,save and exit.
    again configure sata mode.
    if new bios firmware is available means, download and install it
    ROG Member Array
    Apr 2019
    22
    Hello,
    no the settings apply but why that strange message? i also have the message after each clear cmos that says :"After setting up intel optane memory or the raid configuration was built, you must set sata mode to raid to avoid unknown issues".
    i don't see the point in using ahci, this is what i wanted and i can't have it.
    i ve just tried a bios reset and i still have the two messages, so boring,
    Best regards,
    Arnold
    ROG Guru: Blue Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    42
    997
    @ArnoldT
    Your point is moot. Change to ACHI *MAY* result in data loss. Never has for me ever. You should have setup using the ACHI driver from the start. Worst Case blow your current OS and start again with ACHI drivers.
    Windows 10 uses specific drivers for sata mode and achi, changing may cause the existing OS to bork, however Windows 10 has come a long way and YMMV it may be able to recover from this these days, but do your research first and find out the answer.
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    329
    7,927
    Just to clarify, it's referring to a potential problem upon switching modes rather than a permanent flaw in the AHCI implementation. If you install Windows after the switch you will not have any issues. If I recall, when Windows fails to start due to a change in this setting there is a workaround so if you get an error just type it into Google.
