Results 1 to 8 of 8
    ROG Enthusiast Array morpwr PC Specs
    morpwr PC Specs
    Motherboardmaximus x hero
    Processori8700k
    Memory (part number)corsair dominator 32gb
    Graphics Card #1asus gtx1080ti
    Monitor27 inch/vr
    Storage #1samsung 850 pro ssd
    Storage #2samsung 950 ssd
    CPU Coolerthermaltake flo360
    Casecooler master x71
    Power Supplyevga 850w
    Keyboard corsair k65
    Mouse corsair m65
    OS windows 10 64bit
    Oct 2016
    66
    switched from 8700k to 9900k serious issues now
    I thought this would be a simple swap but noooo. Maximus x hero with latest bios that worked perfect before the switch to the 9900k. Now any time i try to use xmp i get constant random freezes,crashes and errors with bsod. I ran the built in memory test in windows and got errors but i cant believe it worked fine yesterday and now it wont. Without xmp it passes the memory test in ixtu and no problems. Anybody have any ideas on this? I did take the memory sticks out and reinstall them just to make sure.
    I havent touched the cpu yet its at stock settings.
    ROG Guru: Blue Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    43
    878
    Did you update the BIOS to at least 2003 ?
    ROG Enthusiast Array MacClipper's Avatar
    Jan 2012
    25
    XMP = overclocking the IMC, check the volts there.
    A Mind Forever Voyaging... Across The Universe
    morpwr PC Specs
    Processori8700k
    Monitor27 inch/vr
    Mouse corsair m65
    OS windows 10 64bit
    Oct 2016
    66
    Quote Originally Posted by RedSector73 View Post
    YES Latest bios.
    morpwr PC Specs
    Processori8700k
    Monitor27 inch/vr
    Mouse corsair m65
    OS windows 10 64bit
    Oct 2016
    66
    Quote Originally Posted by MacClipper View Post
    Not sure what you mean by that. Ive built 3 pcs and never ran into this before with the memory not working with xmp.
    New ROGer Array
    Dec 2020
    1
    Quote Originally Posted by morpwr View Post
    did you reset CMOS after the CPU swap? also when you enable XMP, what are your voltages set at auto? usually there very high what kit are you using? how high Freq Ram? sometimes too much VCCIO and VCCSA it crashes. also DMI voltage plays a role in memory stability to. send a pic of the HWinfo Screen, or install DIPS5 and check your voltages for VCCIO and VCCSA
  7. #7
    morpwr PC Specs
    Processori8700k
    Monitor27 inch/vr
    Mouse corsair m65
    OS windows 10 64bit
    Oct 2016
    66
    Yes i reset the CMOS. Im using Corsair Dominator Platinum 32 gb 4x8 cmd32gx4m4b3866c18. What should the voltages be at? Honestly ive always just used xmp and it worked up until now so i really have no idea what they should be. I have a fresh install of windows now to because stuff was corrupted so i know thats not an issue any more. Ive since ordered some Gskill ram because im starting to wonder if the ram was going. There are a few of us that have instant crashes in Project Cars 3 with vr that nobody can figure out including the devs so maybe the ram was causing the issue?
  8. #8
    ROG Guru: White Belt Array Squall_Rinoa89 PC Specs
    MotherboardAsus Maximus XI Hero Wifi
    ProcessorIntel Core i9 9900K
    Memory (part number)F4-3200C16D-16GTZSW G.Skill Tridentz
    Graphics Card #1Evga 1080 Ti SC Black Edition 11G-P4-6393-KR
    Graphics Card #2Evga 1080 Ti SC Black Edition 11G-P4-6393-KR
    Sound CardCreative Sound Blaster Recon 3D
    MonitorAcer 21.5" LED S220HQL / ASUS PB278Q 27"
    Storage #1Samsung 860 Evo PRO 256GB
    Storage #2Samsung 850 Evo 500GB
    CPU CoolerEvga 280 CLC AIO
    CaseCoolerMaster HAF 932 ADVANCED
    Power SupplyEvga 1300G2 SuperNOVA 1300W Full modular
    Keyboard Corsair K70 RGB Cherry MX
    Mouse Logitech G502 Proteus Spectrum
    Headset Turtle be X07 PRO
    Headset/Speakers Logitech Z 506 5.1 75W
    OS Windows 10 PRO
    Jul 2013
    113
    YES Latest bios.
    Try jumping back to an older bio's back around the 9900K was announced.
    Ram should be 1.35V
    Lian Li 011 Dynamic White Case
    Intel Core i9 Coffee lake 9900K @ 5.1GHz
    ASUS Maximus XI Hero WIFI LGA 1151 Z390
    G.Skill DDR4 TRIDENTZ 3200MHz 16GB (8GBx2)
    2x EVGA nVidia EVGA 1080 TI SC BLACK Edition
    EVGA SuperNOVA 1300 G2 PSU
    1x 256GB SAMSUNG 860PRO SSD
    2x 500GB Samsung 850 EVO SSD
    1x WD BLACK 2TB 7200 RPM 64MB Cache SATA Hard Drive (6.0Gb/s)
