Results 1 to 6 of 6
    ROG Enthusiast Array Swiso PC Specs
    Swiso PC Specs
    MotherboardASUS Rampage Extreme V 3.1
    Processori7 5930K
    Memory (part number)CMD32GX4M4B3000C15
    Graphics Card #1EVGA GTX 980Ti Classified
    Graphics Card #2EVGA GTX 980Ti Classified
    MonitorNEC 30" LCD3090 Wqxi
    Storage #1Samsung 850 Pro 1TB
    Storage #2Samsung 850 Pro 256GB
    CPU CoolerNoctua NH-D15S
    CaseLian-Li PC-V2120X
    Power SupplyCorsair AX1500i
    Keyboard Das Keyboard
    Mouse Steelseries Sensei
    Headset Beyerdnamic MMX 300
    Headset/Speakers CREATIVE GigaWorks T40 Series II
    OS Win 10 Pro - Linux Mint 17.3
    Accessory #1 Samsung 950 Pro 512GB
    Accessory #2 ASUS BW-16D1HT
    Accessory #3 WD Caviar Black 2TB
    Apr 2016
    11
    40
    Zenith II Extreme Alpha EATX12V connectors
    Hello all,
    One qustion...which cable should I use to connect the EATX12V_3 6-pin connector ?
    Will an 8-pin EPS plug fit, leaving out the last two pins ?
    It look like there is only 8-pin or 4-pin EPS type of plugs...
    Thanks
    ROG Enthusiast Array Artureld PC Specs
    Artureld PC Specs
    Laptop (Model)ROG Zephyrus S (GX531) / Apple rMBP 15"
    MotherboardRampage V Edition 10/Zenith II Extreme
    ProcessorIntel 6950X @ 4.1/AMD Ryzen Threadripper 3970X
    Memory (part number)64GB Corsair Dominator Platinum CMD64GX4M8B2800C14 / G-Skill Trident Z Royal 128GB 3200MHz
    Graphics Card #1Titan X (Pascal) w/ EKWB Nickel @ 2034MHz
    Graphics Card #2Titan X (Pascal) w/ EKWB Nickel @ 2034MHz
    Graphics Card #3ASUS ROG Strix RTX 3090 OC
    Sound CardCreative Sound Blaster X7
    MonitorSamsung Odyssey G9 & Alienware AW3418DW
    Storage #1Samsung 960 Pro/ Samsung 860 Pro x2 512GB/ 2x Samsung 1TB 860 EVO
    Storage #23x 980 Pro 1TB PCIE4/2x WD SN850 2TB
    CPU CoolerEKWB X360 Custom Loop/ 480mm EKWB Custom Loop/ EKWB Quantum Velocity sTRX40/ EKWB Quantum Reflection
    CaseCorsair Obsidian 900D/ Lian Li O11 Dynamic XL
    Power SupplyCorsair AX1500i/ Corsair AX1600i
    Keyboard Razer Huntsman Elite/ Logitech G915
    Mouse Razer Mamba Hyperflux/ Logitech G903
    Headset Razer Nari Ultimate/Logitech G Pro X Wireless
    Mouse Pad Razer Firefly Hyperflux
    Headset/Speakers EE-MU7/B&O H8/B&W P7/ Sony 1000XM3
    OS Windows 10 Pro 64bit
    Network RouterROG Rapture GT-AX11000
    Accessory #1 ASUS ROG Front Base/ Elgato Streamdeck
    Accessory #2 Corsair Commander Mini/ASUS RGB HB SLI Bridge
    Accessory #3 Xbox Elite Controller/ Corsair ST100 Stand
    Artureld's Avatar
    Dec 2014
    74
    I got a custom cable from CableMod since my PSU did not have an EPS 6 pin cable in the box.
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,690
    It's a 6 pin PCIe cable...i.e. 6 pin GPU connector
    Swiso PC Specs
    Processori7 5930K
    Apr 2016
    11
    40
    Thank you very much.
    So a common 6-pin PCIe cable then.
    Thanks.
    Apr 2012
    505
    13,690
    Yep...same cable you would plug to a GPU
    ROG Member Array
    Oct 2015
    11
    Quote Originally Posted by Swiso View Post
    Hello all,
    Thanks
    Just want to share an experience I had with this connector. I had an extra cable from a Cablemod kit that had a 6-pin to the PSU and a 6-pin out, which fit perfectly in the SATA power on the PSU and somehow also fit like a glove into this 6-PIN CPU power port on the motherboard. The PIN-OUT voltages actually fried my motherboard instantly. The board lit up for a fraction of a second, and refused to boot ... it was too late. 1100$ (CAD mind you) in the garbage.
    My point is, don't just try to fit something in there ... use the proper cable that is meant to be there. It's not because it fits in the plug that it belongs there !
    Use a 6-PIN PCI-E power cable and connector, the same you would use for your GPU or CPU power. If you don't have a 6-PIN, an 8-PIN actually fits there with 2 pins hanging out. But at least it is the proper cable and pin-out.
    Also avoid ketchup & mustard colored adapters and such ... too much of a risk of wrong pin-outs.
    Different PSU's have different pinouts, and cables often are NOT the same - i.e.: Thermaltake 1250W cables fit Seasonic 1000W PSU, but will fry your devices & potentially your PSU. Don't fry anything else, when you replace or upgrade a PSU, double check the cable compatibility online or by default DON'T trust you old cables, replace them with the included ones. Just sharing another experience that was costly.
    Cheers.
