Odd Issue with upgraded Processor (i9 9900KF)
Squall_Rinoa89
I decided, to move from an i7 9700K to an i9 9900KF and all this went insane on issues.
First, I run 2 1080 Ti's and as soon as i do much of anything my screen will turn off and NEVER Return until I reboot.
I've looked for bent pins, None.
Looked for damage, None.
Tried multiple Bio's, same outcome.
Checked my AIO Cooler.. nothing changes. Not to tight, not loose.. i've retimed it multiple times.. Its NOT temps when it happens.
Replaced my PSU with a NEW 1300W power supply.. still
Changed Display Port cables, still happens regardless. Swapped around the 1080 Ti's.. still happens..
Seriously? is it just this processor? It's either processor, or its my motherboard.
I ordered a Gigabyte Aurous PRO Wifi Z390 motherboard for $199 to see if this issue follows it to that board.
I have a RMA for my Maximus XI Hero Z390 Wifi board. I'm in the current time of talking with Intel also on this issue and looking into buying just a i9 9900K itself again... I also checked on my pegs and everything else and everything is fine.
Lian Li 011 Dynamic White Case
Intel Core i9 Coffee lake 9900K @ 5.1GHz
ASUS STRIX Z390-E LGA 1151
Corsair DDR4 Corsair Dominator 32GB (4x8GB) 3600MHz CAS 18
EVGA nVidia RTX 3080 FTW3 ULTRA 10GB
EVGA SuperNOVA 1300 G2 PSU
1x 512GB SAMSUNG 860 PRO SSD
2x 500GB Samsung 860 EVO SSD
1x WD BLACK 2TB 7200 RPM 64MB Cache SATA Hard Drive (6.0Gb/s)
6 REPLIES 6
metalspider
what driver version are you using on the 1080ti cards?the latest 460 versions have caused issues for me and i had to rollback to 457.51
same here, i had the screen flicker issue. try 457 driver
I have, seems fine solo. Even used an RTX2060 np. Which is weird.
Pretty sure i ran that firmware, ill double check when home..
Ill try those drivers to.
So Far, I went back to 457.51, and actually and very surprisingly.. Not having the screen drop out yet..
RedSector73
Level 12
Have you installed this firmware update
https://www.nvidia.com/en-us/drivers/nv-uefi-update-x64/
yes i have a long time ago,reran it now to check and it says its already updated
did you ever just tried it with 1 card instead of 2?
