Results 1 to 10 of 24
01-07-2021 10:12 AM #1
Tounet PC Specs Motherboard ASUS ROG STRIX B550-I GAMING Processor AMD Ryzen 7 3700X Memory (part number) CMK32GX4M2Z3600C18 Graphics Card #1 NVIDIA GeForce RTX 3070 FE Monitor Dell 32" - S3220DGF Storage #1 Samsung SSD 970 EVO Plus M.2 PCIe NVMe 1 To CPU Cooler Noctua NH-U12A Case Lian Li TU150X Power Supply Corsair SF Series SF750
- Join Date
- Dec 2020
- Reputation
- 10
- Posts
- 12
[Solved] ASUS ROG STRIX B550-I GAMING - Corsair DDR4 DOCP 3600 Problem
Hello there,
First, sorry for my english, i'm french.
My Setup :
AMD Ryzen 7 3700X
Noctua NH-U12A
Corsair Vengeance LPX 32 Go (2 x 16 Go) DDR4 3600 CL18 - CMK32GX4M2Z3600C18
Lian Li TU150X
Dell 32" - S3220DGF
I have a problem running my RAM at 3600 on my motherboard with the DOCP profile.
If everything is by default in bios and I activate the profile, I have Whea-logger event id 19 and randomly a black screen / restart of the motherboard @ idle
BIOS Version : 1401
At 3200 with tight timings, no problem.
From my researches, I see a lot of problems here, on reddit, or on other forums with the ram at 3600 and the XMP profiles?
My ram above is not in the certification list of the motherboard, is this a problem ?
From what I see here and on other forums (reddit), there are a lot of problems with XMP profiles from 3600, is there a problem on the B550 / X570 about this ? The manufacturers are working on the subject ?Last edited by Tounet; 02-11-2021 at 10:52 AM.
01-07-2021 11:11 PM #2
- Join Date
- Dec 2020
- Reputation
- 10
- Posts
- 12
Test with last beta bios 1602.
Same problem
01-08-2021 04:12 AM #3
- Join Date
- Jun 2020
- Reputation
- 24
- Posts
- 70
do they not test these stupid bios first?????
01-08-2021 05:08 AM #4
RedSector73 PC Specs Laptop (Model) FA506IU-AL130T x 2 Motherboard ROG CROSSHAIR VIII HERO (WI-FI) Processor AMD Ryzen 9 3900X 12-Core Processor Memory (part number) 4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die Graphics Card #1 Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC) Sound Card Arctis DAC Monitor Asus ROG Swift PG348Q Storage #1 ADATA SX8200PNP 1TB Storage #2 2 x Samsung SSD 840 EVO 250GB CPU Cooler Coolermaster Liquid Pro Master 360 Case EVGA DG-87 Gunmetal Grey Gaming Case Power Supply EVGA SuperNOVA G2 750W Gold Power Keyboard Corsair K95 RGB Platinum Mouse Corsair Gaming Sabre RGB Gaming Mouse Headset ARCTIS Pro Wireless Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large OS Windows 11 64bit Pro Network Router PfSence Intel i5-10210U 6 Port Accessory #1 TP-Link Gigabit 8&6 Port Switches
- Join Date
- Apr 2018
- Reputation
- 66
- Posts
- 1,329
Make sure you have put your RAM in 2nd & 4th Slot from CPU.
This is LPX Ram which is loot box RAM, the version number & model need approval for it work flawlessly with Ryzen or YMMV. I would not buy this RAM, `imo it is cheap crap.Last edited by RedSector73; 01-08-2021 at 08:27 AM.
01-08-2021 08:40 AM #5
- Join Date
- Dec 2020
- Reputation
- 10
- Posts
- 12
There is only 2 slots as this motherboard is itx
01-09-2021 04:36 AM #6
- Join Date
- Apr 2018
- Reputation
- 66
- Posts
- 1,329
01-11-2021 04:18 PM #7
- Join Date
- Jan 2021
- Reputation
- 10
- Posts
- 14
same problem here with my Patriot 3600 Kit (PVB432G360C8K) it even was on the QVL list for Ryzen 5000:
https://abload.de/img/qvl6gk1p.png
Because Asus removed the List i gues they are aware of the problem. But some official statement would be nice so i would know if i should return the board or not...Last edited by ERDNUSS; 01-11-2021 at 04:21 PM.
01-12-2021 03:59 PM #8
- Join Date
- Jan 2021
- Reputation
- 10
- Posts
- 13
Works fine for me at 3600 and even 3800 on every bios I tried paired with my 5600x. You ram probably can't take it.
01-12-2021 05:37 PM #9
- Join Date
- Jan 2021
- Reputation
- 10
- Posts
- 14
01-13-2021 12:27 PM #10
- Join Date
- Dec 2020
- Reputation
- 10
- Posts
- 12
