Results 1 to 6 of 6
    ROG Guru: Green Belt Array geneo PC Specs
    geneo PC Specs
    MotherboardROG Maximus XII Hero (WiFi)
    Processori9-10900k 5.1Ghz AVX0, delid
    Memory (part number)64 GB G.Skill TridentZ RGB 3200/CL14 @ 3600 CL16
    Graphics Card #1Asus ROG Strix 2070 Super A8G
    Sound CardOn-board
    MonitorEIZO Coloredge CG2730 and Viewsonic QHD displays
    Storage #1Samsung 512 GB 960 Pro; 980 1TB
    Storage #21TB 850 x 1 TB 860 EVO RAID0, 6 TB WDC Black, 6TB IronWolf Pro
    CPU CoolerEK-AIO 360 D-RGB w/Phanteks 120 T30 fan, 2 Noctua Chromax case fanss
    CaseFractal Design Meshify 2 dark tint
    Power Supply750W Seasonic Prime Ultra Titanium Plus
    Keyboard Glorious GMMK TKL
    Mouse Logitech G305
    Headset Bose QC15
    Mouse Pad Perixx dx-2000
    Headset/Speakers Vanatoo T1, Klipsch R-12SWi Sub
    OS Windows 11 Pro X64
    Network RouterLinksys EA7300
    Accessory #1 Logitech c920e webcam
    Accessory #2 Sabrent DS-SC5B 5-Bay USB-C HDD docking station
    Accessory #3 xrite i1 Display monitor calibration
    geneo's Avatar
    Feb 2014
    52
    564
    Hero XII won't post - qcode loop $C 3E 32 &4
    So my system suddenly fails to post. Everything seems to have power , fans spinning, lights on graphics powered etc. It just keeps looping with pauses in qcode 4C 3E 32 74 repeating until I power down. No post or display.
    I have tried:
    - Swapping GPUs and GPU slot. Removing GPU,
    - Swapped processor
    - Doing individual RAMS in different slots.
    - I have disconnected everything not essential - except for cooling and nvme
    - Visually inspected for shorts
    - reset cmos
    - reflashed bios with bios flashback
    Always the same looping qcodes, no post, no display I have run out of ideas.
    Anything I might be missing, sugesstions?
    ROG Guru: Yellow Belt Array Erwin05 PC Specs
    Erwin05 PC Specs
    MotherboardAsus ROG Strix X570-E Gaming Bios v4021
    ProcessorAMD Ryzen 5 3600 @ 3,6 GHz
    Memory (part number)G.SKILL F4-3200C14D-16GFX
    Graphics Card #1ASUS ROG STRIX-GTX1070-8G-GAMING
    MonitorIiyama ProLite GB2488HSU-B1
    CPU CoolerNoctua NH-D15S chromax black
    Power SupplySeasonic PRIME PX-650
    OS Windows 11 Home x64 - v21H2
    May 2015
    186
    Maybe a bad cable?
    https://rog.asus.com/forum/showthrea...3A-32-14-error
    Only install a cpu, 1 memory stick in the 1st slot and a video card if it is possible run memtest.
    Unplug everthing else from the MB.
    geneo PC Specs
    Sound CardOn-board
    Mouse Logitech G305
    Headset Bose QC15
    geneo's Avatar
    Feb 2014
    52
    564
    Said I did all that if you had read my post.
    Can't run memtest if it won't post
    Turns out a removal of the CMOS battery did the trick after all of that.
    I didn't do that first since you have to remover an nvme heat-sink cover to do it.
    SOLVED
    ROG Guru: White Belt Array
    Dec 2013
    19
    113
    Quote Originally Posted by geneo View Post
    SOLVED
    Was the battery dead or does replacing it with a new one still cause the issue? Good job figuring it out, that would have been a tough one.
    Erwin05 PC Specs
    May 2015
    186
    When the battery is empty the pc starts up to the ami bios screen where u can press F1.
    geneo PC Specs
    Sound CardOn-board
    Mouse Logitech G305
    Headset Bose QC15
    geneo's Avatar
    Feb 2014
    52
    564
    ^ Yep. Just dropping the battery power briefly fixe4 it. Apparently the clear cmos button doesn't clear everything as I had tried that multiple times.
    Was near to RMAing it, and I didn't want to go through that experience!
